Street Scoop II and filter element?
My 66 Nova uses a Mr. Gasket, Street Scoop II that is about 3/4 way through the hood (cut out in hood). I recently took the scoop off for carb servicing and found the filter element extremely dirty, probably never changed. The element is an odd size, 6 3/8" diameter x 2 1/2" deep, and I haven't located one yet. i traced the outline of the element and have stopped by a few parts shops but nothing yet. Anyway, I have a couple changes I would like to run by you guys to see if you think this will work.
First off, the street scoop underside has a rectangular mounting area that is about 6" wide x 12" long x 3/16" deep. The adapter that is attached to the 4120 Holley has the standard round ring, which has a flange and plate to attach the scoop to the carb. This is where it gets jenked up. The adapter plate on top of the carb mount ring is only about 6" x 6", leaving the scoop open on the bottom at the front and back. Should this be closed so the air is flowing only through the scoop? I thought about making a plate that would close off the bottom of the scoop, then cut a hole for the carb air way and drill for the mounting bolts, all easily done. This seems like it would provide more cold air to the carb, as it is, rising heat from the engine gets sucked into the open bottom plate on the scoop.
The next thing, should I consider removing the filter element when racing, not easily done, but possible. I may be able to increase the size of the element in diameter, maybe to 7", but that's about it. As for height of the element, there is no way to increase this. I do drive this car on the street and would want some protection from debree in the carb, but also want the engine to breath and breath as cool as possible.
Any ideas?
