Street/Strip 408 SBC...Critique It? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2009, 09:07 AM
Well, now that I've got my new garage straightened out and my hot rod parts out of storage, it's time to re-evaluate where I stand, and take a look at the combination I selected 10 years ago to see if it's any good.
I plan on (hope to?) buying another 1952 Chevy Pickup to put this motor in, for a pretty radical street/mild drag ride. How I get the power to the ground shall be a thread for another day.
My combination consists of:
400 block, 4-bolt, 511 casting, bored .040" over. w/ main studs
Scat cast steel crank, new, stock journal sizes
5.7" reconditioned (shot-peened, polished, etc.) rods
Hypereutectic dome (0.100") pistons (SCR should be about 11.1:1)
Edelbrock Performer RPM heads (#6073) 70cc chambers, 2.02/1.60 valves
Edelbrock Performer RPM intake (#7101), dual plane
Edelbrock Performer Carburetor (#1411), 750 cfm
Comp Cams 18-702-8 Solid Roller Cam 280/280 adv., 236/236@0.050", 0.550/0.550", LCA 110, overlap 60
Summit Extruded Aluminum Full Roller Rockers 1.6 Ratio
I also have a TH400 lying around too to pair it up with.
I used Dyno2003 to simulate these (I know the software is old, but hey...like the parts, I use what I've got on hand), and basically got a motor that has peak hp of 485@5500 rpm and 514 ft-lbs of torque @4500 rpm, with more than 450 ft-lbs from 1500-5500 rpm and more than 500 from 3500-5000. I figure this would make for a fun occasional strip run, and a beast on the street. I really had no guide in selecting these parts ten years ago, and I hope I got lucky and picked the right stuff (I might have picked it anyway, as I got really good deals on most of it).
I am somewhat concerned about the high compression ratio, but have heard that the somewhat large overlap of 60 degrees should help "bleed off" excess cylinder pressure at low rpms, helping prevent pinging. Thoughts?
I am also curious about your thoughts on intake port to cylinder volume ratios. My IP/CV ratio is about 0.20, which puts it at kind of the low end for pure street cars. However, my BMEP is 192@4500 rpm, which is more for a dedicated strip car.
Is there anything in my setup that I definitely need to scrap? Keep in mind that this engine has already been fully machined and balanced, so any changes might have a domino effect as far as costs and changing other components.
Thanks!
Old 03-20-2009, 09:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I think with a good, tailored ignition curve you might be able to get away with that CR, but you will be at the limit, IMHO.
The carb is what I might want to change. A 4779 would be a better choice, I think.
Might want to consider 1-3/4 primaries.
It'll be a beast on the street!
Old 03-20-2009, 04:24 PM
Can you re-do that calculation? According to the paperwork that came with the pistons, while they are domed, the valve reliefs give them a net "dome volume" of -3.5 cc. That's how I came up with 11.14:1. Even that number has me concerned though. So even if I am right, I might want to make a change.
Old 03-20-2009, 06:02 PM
techinspector1's Avatar
Wiki Edits: 326
The dash (-) before the 3.5 indicates a positive volume, not a negative one. It's 180 degrees out of phase thinking unless you really pay attention to the way the piston manufacturers list their products. If this is the piston you're using with 70cc chambers, the SCR is 12.02:1.
http://kb-silvolite.com/performance....tails&P_id=208
Use these pistons for a SCR of 9.6:1. That'll work great with your 236/236 cam.
http://kb-silvolite.com/performance....tails&P_id=234
Plus, the wider rings will seal better in a street motor.
Old 03-20-2009, 07:14 PM
Tech,
I had considered the dome number might work that way, so I compared it with the piston literature, which stated that it should yield a 10.54:1 CR with 76cc chambers. If you do the math backwards from that, the piston has a net positive effect on combustion volume.
***EDIT***
Here is the piston I am using.
http://store.summitracing.com/partde...&view=1&N=700+
***EDIT***
Just so we're square on the exact numbers I am using:
70cc chamber
9.08cc head gasket (4.20" diam, 0.039 thickness)
3.50cc piston relief (-3.50cc "piston dome volume")
82.58cc Combustion Volume
837.2cc Swept Volume
Like I said though...even a CR of 11.1 is somewhat intimidating to me. I'm sure I would be always hearing phantom pings even if there weren't any.
Old 03-20-2009, 08:21 PM
ericnova72's Avatar
More for Less Racer
Have you given any thought to machining some of the dome height away?
I have done this many times to solid dome pistons in order to get a compression ratio to the specs I need when there is no exact off-the-shelf piston available. As far as the balance goes, you will probably be removing less than 10 grams (a sugar cube size piece of alum is 2 grams IIRC), so you really wouldn't be impacting the balance enough to worry about it at the low RPM you intend to run.
EDIT: I re-read your last post, and you are figuring dome volume into your calculation incorrectly. A negative listed volume is material above the flat of the piston's deck(i.e. domed). A positive listed volume would be a dish.
Because of their large cylinder volume relative to the common chamber sizes in SBC heads, 400's are easy to get too much compression in. Your combo with a Flat top piston that had valve reliefs of 3.5cc volume would be very close to the 11-1 you are figuring.
Old 03-20-2009, 09:29 PM
Summit has some 'splainin' to do then, because I see absolutely no way that piston can make 10.54:1 with 76cc chambers...what do you think? They've been advertising that same kit for years with that verbage, and you'd think someone would have corrected them by now.
Old 03-21-2009, 12:10 AM
ericnova72's Avatar
More for Less Racer
Using the calculator that F-Bird linked to, I came up with 10.58-1 with a 76cc head AND the piston down the bore .025" at TDC, close to what Speed-Pro lists. 11.3-1 w/70cc head and piston .025" down bore, and 12.06-1 w/70cc and piston zero decked.
Cutting these pistons down to flat tops will leave about 3.5cc of valve relief and gives 11.11-1 w/70cc and zero deck, or 10.48-1 w/70cc and piston .025" down bore at TDC. Just examine the piston to make sure it isn't a hollow dome, I've done this to the nearly same forged Speed-Pro 400 .145" dome LW2477 piston with zero problems three times
For what it is worth, I would not run a hypereutectic near the compression limit for pump gas without zero decking the block in order to get the minimum quench clearance down to .040". Been there, done that, if it rattles just a few times you will have junk.
Old 03-21-2009, 03:13 AM
Wiki Edits: 326
For those of you who are thoroughly confused by this whole mess, I'll try to explain.
If a piston is listed as 3.5 cc's, without the minus sign in front of the number, then there is a cut in the piston crown, either valve relief(s) or a shallow dish or both. No material sticks up above the flat part of the piston crown.
If a piston is listed as -3.5 cc's, then there is a dome sticking up past the flat crown of the piston. The valve reliefs which are present might be 7 cc's and the dome might be 10.5 cc's. Deducting the valve reliefs from the dome will leave you with a net -3.5 cc's protruding above the flat crown of the piston and this is how the piston manufacturer will advertise the piston, -3.5 cc's.
In order to figure the static compression ratio of a motor with domed pistons, visualize cutting the 3.5 cc's of dome off the piston crown with a sharp knife and glueing it into the combustion chamber. Now, for your calculations, the piston will have a value of 0.0 cc's and the combustion chamber will have a value of 3.5 cc's less than it was produced with.
Let's take this motor for instance. We will need 5 values to figure the SCR.
The cylinder on this 0.040"-overbored 400 has 837.24 cc's.
We sliced off the dome and glued it into the combustion chamber, so the 70 cc heads are now 66.5 cc's.
The piston is now the same as a flat-top with no valve reliefs, so its value will be 0.0
The head gasket, at 4.200" X 0.039" is 8.85 cc's.
The piston deck height is 0.025", judging by the stack of parts (9.000") and figuring a 9.025" block deck height. The OP has never said what it is, but computing at 0.025", the piston deck height has 5.58 cc's of volume.
837.24 + 66.5 + 0.0 + 8.85 + 5.58 = 918.17
66.5 + 0.0 + 8.85 + 5.58 = 80.93
918.17 divided by 80.93 = 11.34:1 static compression ratio.
Old 03-21-2009, 03:43 AM
ericnova72's Avatar
More for Less Racer
To the original poster:
We've thrown a lot of technical info at you, but to simplify it, if you are uncomfortable modifying the parts you have follow what F-Bird is saying. Buy a different piston that gets you the compression that you could live with, weight match them to your current pistons and then sell off the domed set(EBAY?) to recover some of the cost. If you try to use what you've got as it is now without race gas it will go boom sooner rather than later. Hypereutectic pistons have zero forgiveness when put into the wrong operating environment.
Old 03-21-2009, 05:18 PM
I found the source of my error. It turns out their stated CR of 10.54:1 was indeed based on a stock block deck height of 9.025". The mistake of a novice: I bought a 5.7 rod/piston combo that would be zeroed at 9.000". Heck, even leaving the piston 0.025" in the hole like that would likely still have resulted in detonation, since with the 0.039 thickness gasket I got would have resulted in a quench of 0.064". Try to remember I bought this all as a kit, so I assumed it would work together. Somewhat expensive lesson learned though. I know the salesman can't be bothered to hold every newbie's hand when trying their first major project. I know more now and will be more careful.
This does bring me to a related question though.
In general, what are your thoughts on zero-decking a block vs. just using a thinner head gasket (assuming the deck is otherwise square) to end up with a quench clearance of 0.040"? It would seem to me that once material is removed, your future choices are limited, but maybe I'm overthinking it. (Note that I'm not thinking this is the solution to my current problem...just being curious).
I'm definitely going to look into buying some dished pistons to replace my domes, but am I correct in thinking I have no way of knowing if my cylinder wall clearance is exactly right? The last time, my machinist insisted I give him the pistons to get the clearance perfect.
What Is The Ultimate Street/Strip SBC Combo? (Updated) V8Guy427 Engine 5 04-04-2014 12:06 PM
Critique my 406 SBC build Chevtec Engine 9 03-13-2010 03:37 PM
Engine Masters Critique my 383 SBC Build 973kgt Engine 22 11-12-2008 02:14 AM
Please critique this 408 tornado-tech Engine 8 12-05-2004 06:14 PM
Critique my SBC 400 Combo DTL504 Engine 24 11-30-2003 06:37 PM
