sorry, I couldn't help myself. anyways, I've certainly done my research on tunnel rams, so I'm going to give mine a whirl. I just plunked $250 down on a new junk yard hood (the last one got cut to pieces thanks to that victor...) and before any holes will be cut I am going to run it against a torker II with a 800 vac. it'll be easy to test the two since I wont have to pull the distributor or the water cross over (gotta love those pontiacs...), anyways I digress. I'll let ya'll know how they both performed. |
QUOTE Originally Posted by xntrik
Popular Hot Rodding Magazine, December 2006, THE X FACTOR, p 75, David Vizard. He back to back tests a SBC 383 with Holley Strip Dominator and the Weiand Tunnel Ram and the tunnel ram won across the board from below 3500 to 7500 rpm. QUOTE ********************************************** I did not run that test nor write that article. I am only pointing it out. Look at the dyno charts.. At 3500 the tunnel ram was 30 above the other and the lines were NOT convergent downward. They were parallel. They didn't pull it at 2500 so who knows. ************************************************ But he probably is one of those lying magazine writers anyway.. ... they'll lie about anything to promote some rich advertisers' products.. ![]() Isn't that what many people believe????? |
Crazy Mopar Guy that intake is awesome looking.
We have 2 1960 cross rams, one on a 440 magnum and one on a 426 wedge being built right now. The 440 was awesome (its on the engine stand now). |
I never used the long ram intakes (I assume that's what you refer to from 1960) because we could never find them affordably and they were said to hit a shock tower on B body cars, which is what we wanted to run them on.
They were advertised as strong mid rpm performers, many 4x4 guys have used them. |
A single 4bbl or 2 4bbl vehicle can't use carbs that have been on a shelf for ten years without a kit, and likewise the carbs bought at swap meets that sat in the rain for a dozen times aren't good candidates either. Run each carb if you can, and tell us what happens! |
hope its okay to jump in here and ask for advice? i have used multi carb set-ups in the 70s and loved them. today i am putting together a street truck, just to drive now and then for fun factor only. i would like to run tunnel ram with 2 fours. everyone has talked me out of using a cross ram (i think they are the coolest in the looks department. since several of you guys are experienced with the tunnel ram, would you please advise me on what would be some of the decent combos to watch for? i love to buy used or swap meets. my set-up is as follows. 3700 lbs., 4 speed Muncie, 3.73 or 4.10 with 31 inch tall tire. 406Sb, old school camel backs 2.02/1.6 heads with some porting and bowl work. 9.3:1 CR, bullet solid lifter cam that they recommenced-278/286 duration at seat-108 LOB-530/552 gross valve lift-248/256 duration at .050. long tube hookers. i am not a machinist so modifying is not up my alley, but will try anything once. would love to try building a sheet metal intake, but i am not qualified for that. cam i have is 2500-6400 rated. i think it will be a little different then that on 400 inch motor. i will mostly run engine to 5500 with some 6000 blast. any recommendations?
![]() Tunnel rams aren't "best" in every scenario obviously, but because they are not used OEM does not mean they are an inferior product. What's better- Jesel belt, or a nylon tooth timing set? An ATI Superdamper or OEM damper? Etc etc. Tunnel rams aren't cost efficient, they don't lend themselves to low, sleek hoodlines, and since a single 4bbl platform suffices in almost all factory endeavors, there really is no reason for the manufacturers to even look at tunnel rams for OEM use. I can't think of the last 3x2bbl or dual 4bbl factory car since the early 1970s in fact?
Fuel distribution is more important than most people realize. SFI is equal air and equal fuel, right?
Check out the new Barry Grant inline 4bbl for smooth fuel distribution. Far superior to any single 4 bbl. Multi carb, 2x2, 3x2, 4x2, 6x2, etc, all came about because there were NO 4bbl carbs until 56 or so, then limited production, no manifolds available, and very expensive. Then 4x2. Finally single 4bbl became the standard that most people think is THE BEST. It is only convenient, less expensive, and more trouble free. Early versions had 3" runners mixed with 10" runners, e.g. GT-350 Cobra, F4B, etc. Tunnel rams equaled runners out at about 6 to 10", and smoothed fuel distribution across the board= more power across the board. Look at the runners in the new generation single 4bbl intakes, Perf RPM, Air Gap, etc. |
I know this is a very old topic. - Are there any updates seen since the last post on this topic?
| Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 | nmrajames | Hotrodders' Lounge | 0 | 07-26-2006 09:53 PM |
| street tunnel ram length? | Augusto | Engine | 0 | 05-22-2006 09:44 PM |
| 427bb with tunnel ram ??? | inkfixer4 | Engine | 4 | 08-24-2004 08:41 PM |
| Tunnel ram OR NOT ?? | ss crazy | Engine | 11 | 09-09-2003 09:57 AM |
| Tunnel ram? | HemmiGremmie | Engine | 5 | 09-02-2003 05:40 PM |
