Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Street Tunnel Ram
Old 08-14-2002, 05:33 PM
roys63's Avatar
roys63 roys63 is offline
Post
You can make this work using the 450s and run a vac balance tube or hose between the secondary housings and use the heavy diaphragm springs. you need atleast a 3.70 - 4.11 gear in the rear or so. This will work a lot better with a stick shift or a high stall converter,I have had a set up like this and run it right though the winters never changed a thing for 3 years on a 327 loved it!Thats not the only one i have set up over the years.Have Fun!
