streetable 500hp 327? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-20-2005, 07:26 PM
You won't find the intensity of the lobes an higher in a HR cam, they are less intense. You can look at all the Comp Cam lobes at:
http://www.compcams.com/Technical/Cu...ML/238-273.asp
We use a Camcraft cam in our 331 - a 50-4040-10A4 roller, 240/240 on a 110 LSA installed at 106. It puts nearly 420 hp to the rear wheels and is very driveable.
http://www.camcraftcams.com/catalogs/xtl/tm_roller.htm
  #17 (permalink)
Old 12-20-2005, 07:41 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Contact the manufacturer of some of those cams. Also read the manual for the DDyno. Just because its a roller cam doesn't mean you should use the "roller" setting on the simulation. The manual will tell you more, but the lifter style setting has nothing to do with the actual lifter or its friction, it has to do with the ramp profile. Setting it to roller will make it think you're using the absolute most aggressive ramp profile but most cam manufacturers (especially in the range you're using) don't grind them that aggressive. For that duration I would simulate it using the solid flat lifters.
Also the exhaust makes a HUUUUGE difference. I noticed you simulated with open exhaust which is absolutely not streetable; legally or audially Plug in large tube headers and full exhuast and the solid flat lifters to simulate the ramp profile and I think you'll find your 500-hp screamer is a 400-hp streeter... still very respectful, but more realistic.
DD is incredibly close if you use it right. I'm always within 4%, but often times within 1 or 2%. It only took me about 8 years to get that good with it
  #18 (permalink)
Old 12-20-2005, 08:28 PM
Within 4% of what? How do you use it right? When I was using DD I could never reconcile the exhaust system, where you are limited to about 4 choices. There were no provisions for accessories, windage, friction, runner length, etc.
  #19 (permalink)
Old 12-20-2005, 09:29 PM
rlackey's Avatar
Rich Lackey
Last journal entry: Rich Lackey is back on Hotrodders!
Ok, I'm going to run it again, I'll post the results a bit later.
Rich
  #20 (permalink)
Old 12-21-2005, 01:10 PM
curtis73's Avatar
Wiki Edits: 16
Within 4% of the actual engine's power after it was built. I've used it to build a pontiac 389, a pontiac 455, two 454s, one buick 455, three Ford windsors, and a caddy 500. The Caddy was within 2 hp
You can get sorta close with DD if you just plug in stuff, but to really get accurate with it you have to have an almost intrinsic grasp of VE theory and how it affects every aspect of the other parameters you've put in. The fact is that the subtle differences between windage trays and friction aren't part of what DD can predict. DD uses VE... that's it. A windage tray may or may not do anything for power depending on its design, RPM, and which aftermarket tray you're using. You can't predict friction, nor can you plan on it, but friction doesn't account for how an engine SHOULD perform. That's all DD does. It assumes you are using the proper level of octane, your spark curve is perfect, your fuel curve is perfect, your friction is within tolerance, your oil pump is providing a standard torque loss, etc. Its just a tool for estimating how much air it ingests based on physics, then how many BTUs can be released from the fuel corresponding to the amount of air you've ingested. Then it calculates the force to the piston and integrates it with the leverage on the crank at all 360 degrees and bingo... torque estimates.
The thing is, DD uses VE to estimate a torque curve and extrapolates hp. Using its current details, you can get darn close. If you start delineating between 2.5" and 2.25" exhaust tubes and their length, windage trays and their effectiveness, and other small details, not only will it add just a tiny bit more accuracy, its also more junk for the end-user to abuse. On a simulation, everybody uses a windage tray, 4" exhaust, and low friction rings, but on the street we have wallets, ears, and vacuum advance canisters that dictate what parts we use.
DD estimates crankshaft tq, so accessories aren't a factor, nor are drivetrain losses or altitude since it assumes that in the hands of the experienced user, you know that it assumes STP at sea level and you have to base it on your climate and altitude.
DD in the hands of a pro builder is highly accurate since he/she knows by experience how much they can expect from a Milodon windage tray in a Mopar 440. In the hands of a casual user it usually ends up highly optimistic.
  #21 (permalink)
Old 12-21-2005, 02:34 PM
I was asked to work a spec engine project about 4 years ago. The goal was to have a very low compression low maintenance engine with a max of 6000 rpm. We need to sell it for 5999.00
Here was the build
355 CID
9 to 1 Hypereutectic pistons
Brodix Spec Head
Brodix Single Plane Spec Intake
Holley 4779 out of the box
Hyd Cam. I had Richard at Isky grind this it was 250 @ .50' and around 540" lift single pattern on a 108 with 4 degrees advance ground into it.
Timing was at 34 degress (conservative)
Gas was 93 Octane
Engine Made 424HP at 5800 rpm and around 475#/ft of torq around 4400.
This thing was mild for a circle track engine but there is no way it would be "enjoyable" on the street. With your project to make that kind of power you are going to have to turn it up.
  #22 (permalink)
Old 12-21-2005, 03:52 PM
After I develop this 'intrinsic grasp' of VE theory, how do I fudge the inputs?
  #23 (permalink)
Old 12-21-2005, 04:19 PM
curtis73's Avatar
Wiki Edits: 16
You don't fudge inputs. If I'm simulating building a mild 307 roller Olds, I use the hydraulic flat lifter setting. Why? Because of the ramp profile on the cam, not the lifter. The amount of air flowing into the engine doesn't care how much friction there is at the tappet. It takes a flow curve and calculates how much time the valve spends at certain lifts using the ramp speed as part of that equation. It uses that to determine how much air actually makes it into the cylinder. Ham-fisted newbies would just put "roller lifters" since it uses roller lifters and their numbers would be way off.
Its not fudging. I have discovered that every once in a while I can mess with exhaust lift or duration by one degree or .010" lift in either direction to help simulate a full exhaust in a long station wagon versus a short Chevette, but its by no mean science. You're better off letting DD estimate what the engine would do on a dyno stand then being realistic about the actual installation. I came up with 400 hp on my latest 454 build. The actual numbers were 412 on the dyno with a water pump and 2.5" straight exhaust and 40-series Flowmasters. After I installed it with a power steering pump, alternator, and full 2.5" exhuast with 70-series mufflers and several bends, I'm guessing in the area of 390.
You're trying to get too specific. DD is not designed to make perfect guesses based on every aspect of the installation. That's for the installer to determine. Your best guess is to put it on a chassis dyno, but then how much do you estimate for drivetrain losses, exhaust losses, driveline angles, etc?
Nothing is exact. I simulate engines on DD and test the built engine on a Dynojet. If I took that same engine to another dyno I might be 20 hp off. What that also means is that my accuracy with DD is pointless since its based on one dyno bay. The actual amount of HP that finished product makes is a complete mystery and can never be duplicated twice... even on the same dyno. Back to back runs produce different numbers on the same machine.
  #24 (permalink)
Old 03-02-2009, 05:47 PM
jjfarr's Avatar
327 500hp
Update: Check this out for all you who doubt the 327 SBC has the most HP per inch potential: http://www.chevyhiperformance.com/te...ild/index.html
  #25 (permalink)
Old 03-02-2009, 05:56 PM
Jmark's Avatar
Yahoo!!! But only a measly 10 grand too! LOL
  #26 (permalink)
Old 03-02-2009, 07:43 PM
Popular Hotrodding had the '09 Engine Masters' tournament in their most recent magazine. There was a 327 in the pages that made in the neighborhood of 540hp. Check it out, it may still be on the magazine rack or look at their website, might be on there... anywho, seems like I remember reading they were using an AFR 210cc head (or a 15 degree GM Bowite head- or maybe that was on a 302SBC in the test) with a 2.1 intake valve and a comp cams solid roller, something like 260 adv. duration and .638 lift.
In my very humble opinion you might not need the parts they used but something similar should point you in the right direction.
  #27 (permalink)
Old 03-02-2009, 08:18 PM
jjfarr's Avatar
10K buys Alot
LOL. Worth every penny!
  #28 (permalink)
Old 03-02-2009, 08:22 PM
4 Jaw Chuck's Avatar
Someone told me they were racing dyno programs in here?
You kids are gonna get caught by the cops racing them things.
  #29 (permalink)
Old 03-02-2009, 08:26 PM
jjfarr's Avatar
Cops Suck
What up Jaw Chuck? Spin'em higher!
  #30 (permalink)
Old 03-02-2009, 08:38 PM
jjfarr's Avatar
Sorry Guys. Didn't mean to scare you!
Just havin fun! Twisty!
DZ 302 Vs 327 ???? oc00l Engine 37 11-18-2008 09:53 AM
help make my 327 angry!!! 70chevelle327 Engine 40 04-24-2007 05:33 PM
327 build up using 1964 and earlier parts ONLY chopperimpala Engine 23 10-06-2005 01:07 PM
327 TO 350 CONVERSION 34FordPickUp Engine 4 08-27-2002 05:56 PM
327 rebuild help. SUGGESTIONS PLEASE DeezImpala Engine 1 06-24-2002 09:06 PM
