I am planning on building my 1st street rod. The StreetBeast kit's look interesting. Anyone have any experience/references with these? Thanks. Don
You forgot to mention the fact that its an educated opinion. I've been following CMC/Street Beast's escapades for almost 20 years. I've toured their (CMC's) facility and personally knew a couple CMC employees. Don't tell me I don't know anything about the company.JGK95 said:......If a person like centerline doesn't have the first hand business dealings with Street Beasts, then he is reduced to only offering an Opinion.
Once again you can't argue the point without attacking me personally. I badgered you? Thats interesting. You are the one who continues to resort to name calling, and you are the one who is consistently berating ME personally. I have not called you names (other than novice and inexperienced) nor have I attacked you personally except to say that I thought your purchase was ill-advised. It would appear based on your recent posts that you are doing a good job learning "spin techniques" from your buddies at StreetBeast.JGK95 said:......To constantly badger and berate new members with this opinion repeatedly, is very, VERY unprofessional and unbecoming of a "moderator".
And exactly where is THAT written in the rules?? Moderators are expected to administer the rules and deal with everyone equally, not be opinion-less. I'm so sorry that you don't understand this simple philosophy, but I'll chalk that up to youth and inexperience.JGK95 said:......Moderators are supposed to be impartial. You know what the old Grandmothers said..."If you have nothing nice to say, don�t say it."
Like I said earlier, I lived less than 5 minutes from CMC's facility when it was located just north of Ft. Lauderdale. The same one where Grampa Cobra said the "Speedster" was stolen from the roof. I toured the facility back then and what I saw was anything but impressive to say the least. What is really surprising is that they are using the same basic design even now.JGK95 said:......As a First hand participant in dealings with Street Beasts, they've been nothing but cordial and receptive to my questions and comments to date.
Why is that??? Have you run out of names to call me or something???? Only time will tell.JGK95 said:......It's that one guy that I've mentioned above who's ruining the experience for me.
I know!!!!! I was not going to say no more....But I couldn't help this one...powerrodsmike said:He also said he has patched up a few Street beast bodies where the trunk openings had cracked on all 4 corners. 3/8 fiberglass didn't help there , did it?
later, mikey
I can't see the pic either.home brew said:NEW INTERIORS - I can't see the pic.
I know the feeling. I read the first 33 pages word for word.327NUT said:My eye's are shot!!!!! The End ?..............uh, I don't think so.
I know what you meen. It is difficult to keep track of where you are at while scrolling down through the posts.JGK95 said:For the Love of God, please write in paragraph form! I read a brick back there of text!
Jay K.
Jay what he told you is the proper way to bottom out the studs if they are not pressed in all the way. To use that proceedure to re-align studs is a bad thing because in actuallity you are racking the stud in the hole and that distorts the hole...in essence making it a little out of round...this little bit of extra hole can cause the stud to rock and cause your wheel to loosen up or worse come off. I was a ASE Tech for over 38 years and I have been a hot rodder longer than that. It may not ever happen , but it is a possibility. Please do not use that hub.Please do not take a chance and run that hub. Sorry but I just never did like paragraphs. I can understand now why the Streetbeast guys did not want to publicly tell what they told you to do about the hub.JGK95 said:Henry,
THE FIX:
Mike S. aka Grandpa Cobra recommended the following:
1. Remove the wheel.
2. Take a wide 1/2 washer and a wheel nut flipped upside down and use a socket wrench to tighten the wheel nut until the wheel nut and washer are flush to the hub/rotor. Doing this should properly align the lug within the hub.
3. Remove both inverted wheel nut and washer and attempt to remount the wheel once both lugs have been realigned.
4. Once the wheel is remounted all is good.
I'm sorry I don't have any pics at this moment of the hub, but upon close up inspection, (of which pictures will be posted) the hub appears to be safe and normal. If the lugs within the hub were even at a 15 degree angle, of course I'd be upset. But these were barely out of alignment and prevented me initially from mounting the wheel.
I do hope this helps those who are following my build.
Jay K.
Modern cars have hubs with lugs too. You should be frustrated with how Streetbeasts is handleing this...they are not being straight with you. They should have replaced the hub no questions asked. Very poor customer service and we already know from the way they conducted thierselves in this thread...very poor public relations.JGK95 said:Mikey,
As someone who's never dealt with hubs that contain lugs, (I only have experience with Modern cars) you have to understand this is all new to me. Trust me, I was frustrated when I didn't see a modern rotors and disk brakes but soon learned that this was the way things were done in the past. Well, I'm up for the challenge.
It is not your inexperience that worries me, it is the response that you got from someone who is supposed to be an authority on the stuff they sell. It is a good thing that you have access to experienced people here on the board that will give you unbiased , correct information.JGK95 said:Mikey,
