You know, Grandpa Cobra, I believe you. Sharing technical advice with folks who you may or may not ever make money from is one of the things that makes the world a better place.
No matter what company you work for. We regularly did the same thing at Poli-Form, that is one of the things that made me like working there so much. BTW, You violated none of our guidelines in your post, you can use names of companies, if you choose, but watch out for lawsuits..you know how SOME companies can be about that..... hahahhaah..don't take that personally.. Pepi still doesn't explain why he removed most all of the parts from his car that would truly make it a look like and really be a 1934 Ford. Having the hood side panels, splash aprons , fenders fuel tank cover are some of the things that make a 1934 ford one of the most beautiful cars of that era. And why he didn't stop with just taking the fenders off, but hacked the rear of his car into a butt ugly something with no flowing lines, and removed the compound curves that are the signs of artistic craftsmanship that even the most basic cars of that era had....So yes, Pepi, you would do well to pass the responsibility of properly educating others about automobile bodies and their design, both aesthetically and structurally to someone else, you get an e for effort though, and another e for ego. Your arguments are weak, and demonstration of the knowledge you continually say you have is just not evident. You can continue to believe that you are a great hot rod builder, and know all there is to know, but I know better. Anyone can check out more of Pepi's car here, and make up their own minds. I found that one day a while back doing some searching of old posts here. Check out his lower body modifcation, didn't Ford make those lower bead edges have curves on the bottom of the body? Hmmmm maybe the oh so durable steel rusted out, and the necessary talent to properly replace that lower bead just was not available at the time..... I don't need some club of guys handing out trophies to tell me what looks good and is right. The favoritism and cronism practiced at most of those "competitions" makes them just one more spectacle for the masses. I don't feel the need to have a car of my own, when I can get paid to work on many dozens,(hundreds probably), of hot rods and exercise my talents. The proof of my talent lies in the fact that if I did substandard work, with no advertising, ( I do not advertise....word of mouth only),soon I would have no work, and would need a job in some other field...like you.. Jay, I think Yogis has the grill insert, they had no picture of the one they sell on the website. You can make up your own mind about whether or not it would be a worthwhile change, Never having seen one of the ones that Yogis is selling, and only having heard that they have more teeth than the SB grill, I can't say for sure that it is. Let us know if you find out more about it. Brake and fuel plumbing is one of my favorite activities, along with wiring..the job satisfaction is great when it's all done, and looks good, and works. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 05-22-2009 at 10:01 AM. |
just curious,
why you don't have a trunk on your car Pepi ??? ![]() And Jay...Keep up the good work... |
I like building them, driving a car is not a priority with me. Anyone can drive a car, it takes talent to build one. Quote:
Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 05-22-2009 at 05:18 PM. |
Thank you all for the kind words of support.
Yesterday, my father, myself and two friends spent the better part of the day putting the fiberglass shell on and off of the frame for a total of five times whilst we tried to figure out the trunk bay. A significant amount of time and complexity (and a few curse words) went into getting the trunk bay to line up properly. The issue might be around the molding of the trunk bay in that it might not have set properly when it was being cured. But in true Mikey-like determination, we solved that riddle and called it a day. Now it sits beautifully in the car and right above the gas tank which we mocked up for a temporary fitting. Jay K. ps. Did I mention that fiberglass spurs in your fingers really hurts?
my SB 34'
I am still trying to get the journal to get my pics uploaded, trouble every time. I have the IFS tacked together and will weld it up the touch up the paint next. I have been measuring for the rear axle, seams what SB says to use will be way to wide, any thoughts?
http://www.barrett-jackson.com/appli...vecarlist.aspx Number 512.1 is a S/B. I don't care enough to spend the time looking thru the others being my computer is so slow. But there you are, a list of cars that have went thru B/J. Brian |
The description does say steel car, 2 times. The pics show what appears to be a steel car, or reproduction fiberglass, at least the frame (what you can see of it through the fender) appears to have the taper indicative of a repro or original frame. (SB cars have straight frame sections) The grille appears to be a Ford or replica of a 33 as well. (it has the distinct curvature of a 33 grille as well as the normal amount of teeth.) You can also see welting between the fenders and body. SB cars are one piece body/fenders. Click on a picture and when the pic appears, hold teh ctrl button and use your scrollwheel to make the pics bigger, they are pretty clear, and high resolution when they enlarge.
http://www.barrett-jackson.com/appli...2.1&pop=0&it=1 That car actually sold 2 times on B-J, once in 2006, and again in 08. in 06 it brought 81K, in 08 it brought 55K...someone must have left a stain on the interior or something. HahahahhaahLater, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 05-23-2009 at 12:23 PM. |
We have a 9" Ford from StreetBeasts and it doesn't look any different. Call Mike S. @ StreetBeasts and he can help you with your measurements. Jay K. |
They used a ford mustang rear end and my 34. 8.8..It is to wide for the car..That's why you see them sit high in the back and front.The wheels are usually sticking out the side of the car.You sure won't put any deep wheels on it.
Brian |
Here is a Streetbeast 41 Willys that sold for only 50 grand (includes the 10% buyers premium) at Barrett Jacksons.
http://www.barrett-jackson.com/appli...9&aid=51&pop=1 |
Streetbeast
Donaldm605, I wish that I was as intelligent as some of these detractor types! I've had a Streetbeast '34 Ford on the road for seven years and have had absolutely NO issues with the frame, body or suspension! In fact, No problems! For me, the car is a joy to drive, it tracks perfectly straight, is comfortable and handles well! (I also have a C4 TT Porsche that makes 742 HP on the GROUND, so I know a little about cars.) The assembly manual is easy to follow, is bound in a 3 ring binder. Factory support was fantastic!
Front suspension is mustang II, rear has coils, to which I added internal, inflatable air bags, 14" wheels front, 15" rears. Front disks, rear drums, ps, pw, tilt, ac, am/fm stereo w. cd, shaved handles. I don't understand the BS about the frame either, it is ane hell of a heavy duty piece. The body is HEAVY duty glass, and is mostly one piece when finished except for doors, trunk lid , hood and engine side panels, NO rattles except what you bring on board! I don't know how it compares $wise to other "kits" nor do I know about resale, and dont give a sh!1 as I don't plan on selling it! Moral of the story, don't knock it till you've tried it! TJN |
| Recent Hotrodders' Lounge posts with photos |
