I happen to have one from Classic Motor Carriages that came with my purchase but I would be there all day if I had to copy it. Would be nice if you could find a online copy somewhere. |
Streetbeast rod kit's
They had a auction at streetbeasts building. it is owed by the Government now, unless they sold it. You are in luck, I just happen to have the book it is unused, in pristine shape, and if you send me a PM with your address I will send it to you. If I were you I would thumb through it then throw it in the trash. I really think you can build the car better without it. You will find that when you put tires on the front you can't get the fenders over the tires so it will sit a little high in front,IMO, so it looks more like stock, than like a Hot Rod. PM me if you want the book, with your address. Bob Last edited by 35terraplane; 06-11-2011 at 10:16 PM. Reason: add, |
Anybody building a streetbeast, 34 coupe or the vicky
The book is ok for figuring out some of the parts you need and for a little reference info, beyond that it's trash. But the absolute best place to go is YouTube... just type in streetbeast... I downloaded all the videos on the 34 Coupe build from Southwest Rod and Custom to build my 34 that's been sitting for 20 years... Pete has all the best tricks of the trade, makes it a lot easier. Hope that helps, sure helped me out!
Looking for a couple of pieces to finish build
Have a nearly complete '34 Ford Coupe Street Beast lacking just the rear window trim, outside, and the hood latching system. Any sources? Anyone have these pieces laying around?
Thanks! Bart in FL 561-358-6456 |
Mine has a insert that goes around the back window, I don't have any metal bye my back window. I have a early body so mine might be different than yours. As far as the outside, that's how any 34 is no outside trim. Bob |
I misunderstood you. With that said I have a insert that slides in from inside the car, through the head liner and around the back window. I fiber glassed my headliner in then you fit the insert, which has a lip on the inside that fits against the headliner, which makes it look like molding. Bob |
23, I won't be taking any pictures any time soon, I'm in a care center with a broken leg. I don't know how much you wlli see. Bye the way I don't have the steel on the headliner, I made my own out of wood. There were none with mine.
Bob |
Bob I apologize I was referring to Bart (btsave) forum member and wrote your name in by mistake as Bart asked the question about the window trim. Must be the heat yesterday getting to me as our central air went down and I had too many things on my old mind.
Question to you Bob. How old is the body on your car? Is it before '92 when I got mine? I thought all of the 34 Classic Motor Carriages,Fiberfab,SB kits had metal cages going through the roof. You must have metal in place in both door jams left and right where other Manufacturers bodies used wood I am assuming. If so I can't help but wonder how you used wood in place of the steel frame tubes. |
| Recent Hotrodders' Lounge posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
