Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - StreetBeast rod kit's
  #217 (permalink)
Old 06-16-2008, 12:50 PM
matt167 matt167 is offline
Wiki Edits: 31
Originally Posted by JGK95
Matt,
Thanks,
it's not the weight of the body but rather the garage door / low ceiling to get the body off of the chassis with the upright bar for the pedals that should prove to be a clearance challenge.
you may have to lift the body up as high as high as you possibly can, then have someone roll the frame out.. or cut the rest of the crate down to clear everything, then slide it out.
