Streetbeasts Rack and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2012, 02:53 PM
I have a Streetbeasts 1934 Ford 3-window coupe from roughly 1991 I purchased the car used in 2007. I need to replace one of the tie rods but have no idea who made the rack and pinion on the car, All I can find is a serial/part? number on the unit that is 35 50073 or something near that. It's a manual unit. The tie rod needed in the one for the passenger side The "cup" that attaches to the unit has like a 3/6" thick jam nut on it the same size as the "cup".
Old 07-20-2012, 02:57 PM
Most of the " Street Beasts " use a Mustang II front suspension and parts. Go to NAPA and they should be able to MATCH THEM up.
DEUCE ... Moderator
Old 07-20-2012, 03:11 PM
Been there
I was at the local NAPA this morning. They can get the tie rod for the manual steer unit but I was curious who made the units Streetbeasts installed on their frames. I had the car in for a front end alignment and the tech noticed the tie rod was bent so I am looking for the replacement. Trouble is I'm not sure it's a standard part or is the one on the Streetbeasts some after market custom job. all of the tie rods I've seen in my search don't use the jam nut which gets installed before the tie rod.
Old 07-20-2012, 04:28 PM
35terraplane's Avatar
Streetbeast
All the street beasts I have seen use Mustang II racks as far as who made it no idea, if there is not a name on it. Mine fit fine and I have a manul Rack.
Bob
Mustang II rack and pinion, pinion Jim H Suspension - Brakes - Steering 3 02-23-2012 12:58 PM
s 10 rack and pinion 64chevyii Suspension - Brakes - Steering 3 01-24-2012 07:54 PM
rack and pinion noreastfish Suspension - Brakes - Steering 2 11-23-2009 10:34 PM
rack and pinion Gassed 64 falcon Suspension - Brakes - Steering 2 09-08-2004 04:47 PM
Rack and Pinion bigvofnash Suspension - Brakes - Steering 3 08-11-2003 12:13 PM
