Stretch bolt gauge ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2004, 09:38 PM
I took a peek in one of this month's issues of a car mag and there's an arttical about the stretch bolt gauge and why they should be used instead of torqueing the rod bolt's like most of us do. Just want know if one of these gauge's are worth $80. buck's from Summit to tight'en down my ARP rod bolt's in my 355 sbc that's only gonna be driven on the street as a dailey driver.
Old 06-18-2004, 10:50 PM
Using the tool is the prefered method. If you cann't afford one maybe you can barrow one. It's possible to tighten to stretch without the tool miking the bolt before torqueing. Tighten the bolt to 1/2 the expected torque required and remike. Now tighten in 5 ftlb steps miking at each step.
Old 06-18-2004, 11:06 PM
WOW i think im lost, it's problebly better for me to just buy the tool and then ill have it for other build's. but in any event thanx for your responce (tresi)
Old 06-19-2004, 12:46 AM
willys36@aol.com's Avatar
Wiki Edits: 21
The whole idea of torquing a bolt is to put a specific tension on it to carry a load. It is a precise stretch of the bolt that is the goal and torque is a secondary indicator that is close enough for government work in most cases. In critical apps like super pressured vessels in refineries and the space shuttle, only a bolt stretch gauge is acceptable. For auto work it is overkill, Unless you are building a 7000hp top fuel engine (and even those guys use torque wenches) I wouldn't sweat it.
Old 06-19-2004, 01:10 AM
Thanx for the profound articulation (willys36@aol.com)
Old 06-19-2004, 07:22 AM
King of my Man-cave.
By using a stretch gauge you will be tightening the fastener to it's best ability to hold. We have found that with aftermarket rods, the torque specs. that you get with them are not jibing with the stretch specs. Using the stretch gauge will ensure your rod fasteners will hold. Having said that, we also find that when the fasteners are tighened to the proper stretch spec, the rod may have to be honed round again or resized to bring it back to round.
tom
Old 06-19-2004, 11:25 AM
LilSmoke's Avatar
very true Tom,also their are different qualitys of guages also. Its just like changing rod bolts, always resize when changing rod bolts as they all pull different on the caps.
