strip new 2k for epoxy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2005, 06:45 PM
staircasesurfer's Avatar
alex p
Last journal entry: AHH
i primed almost half my car with acrylic urathane high build primer on bare metal, after reading everyones recomended use of epoxy on bare metal, should i strip the car of the newly primed areas and re prime with epoxy primer? im not sure if i should do that or just finish priming with urathane?
Old 05-18-2005, 07:52 PM
What kind of car is it? Is she a keeper? If you plan to keep it for longer than a few years I would definately redo it starting with an epoxy primer. It is a lot easier to start over at this stage than to restrip the whole car after paint. Some urethane primers are better than others but none offer the adhesion, durability, and moisture resistance of an epoxy. Read up, do some searches on epoxy primer, determine how long you need this job to last, then decide from there I guess. Bob
Old 05-18-2005, 08:09 PM
alex p
i wanna keep the car, i also live by the ocean, lots of moisture, how much epoxy primer should i need, i have a 72 buick skylark (same size as a chevelle) i plan on covering the epoxy with a high build primer so i can block san it to get it real straight. does this sound good? this is the first project i have done, so thanks for the help
Old 05-18-2005, 08:34 PM
You'll need at least 4 quarts of sprayable epoxy for the exterior surfaces, you'll need to apply two medium wet coats over the bare metal then apply your urethane surfacer primer. Wear a good mask and spray with good ventilation with all of these products- watch your health! Southern Polyurethanes Inc. is an option for the primers and clear. Bob My 15 year old Son is also working on an old project car-http://community.webshots.com/album/117226417GuAuSn?495
Old 05-18-2005, 08:41 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
I guess you already have the primer. I was going to suggest using a polyurethane primer like Feather Fill 2 or Slick Sand if your planning on doing ALOT of blocking.
A couple of coats and you can level that baby right out without having to keep reapplying regular 2k stuff.JMO.
Old 05-18-2005, 10:06 PM
alex p
ya thats what i was planing on doing, but should i just paint over slicksand or do i need to do any thing else., im going to buy 2 quarts of spi epoxy whick makes about one gallon sprayable primer, what size tip do i need to spray slicksand.
Old 05-19-2005, 05:27 AM
Instead of slicksand you could use Featherfill 2G, this is a little finer product and will spray out of a 1.7 tip OK. Great stuff IMO, absolutely no shrinkage, sands nice, and available in three colors. It sells for $38-$65 per gallon in this area. You can paint directly over it. Featherfill 2G
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
Question about epoxy over 2k misteryu Body - Exterior 4 08-31-2004 04:59 PM
"Basic of Basics" What are the new paints all about? Centerline Body - Exterior 0 07-26-2004 06:43 AM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
