Strip yer lifters! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 01:17 PM
MorrisonLC's Avatar
Strip yer lifters!
Following some advice I read on here I just finished taking apart and cleaning a set of SBC hyd flat tap lifters, brand new, Speed pro cheapies. I imagine someone on here could tell us where they're being made now, but I don't care--it's the last set I buy. In 16 lifters I found 6 with the valve plate in upside down, one with 2 valve plates in it, and one with a nice shiny chunk of brass under the piston. In addition 3 or 4 had really sloppy machining inside where you could see the drill had galled at the bottom of the hole. I don't wanna put these things in my engine!
Old 01-20-2009, 05:27 PM
Buick Hybrid Guy.
Our Buick's have a bad problem with eating cams anyway. Plus the oil companys took out that zink and it wipes too hard on a flat tappet.
GM lifters are more expensive but have a nice hard pad on the bottom so you don't fish bowl them. That's what I'd buy if it had to be flat tappt.
Good luck,
Scott~
Old 01-20-2009, 05:33 PM
MorrisonLC's Avatar
Right, GM part #12371044-16 for a set of those. That's what I'm getting.
Old 01-20-2009, 05:46 PM
interesting all the speed pro lifters I've used have been A#1. I did hear some of their piston line is being manufactured in India now but I have no proof of that.
AC Declo lifters, not sure of part #, are still excellent.
Old 01-20-2009, 05:57 PM
CNC Blocks Northeast
The AC Delco lifter are the best I have found
Old 01-20-2009, 06:06 PM
That's what Im using. Cheap too!
Old 01-20-2009, 06:09 PM
Cheap? I must have got ripped off- $89 and that was through a friend with a 20% discount at the GM dealership... if I may ask where did you get yours?
Old 01-20-2009, 06:20 PM
I have rollers. I was commenting on AC Delco being cheap in general to the general availability of other brands. I paid $120 from Scoggin Dickey for roller lifters. Compare at $600 from GM Performance.
Old 01-20-2009, 10:36 PM
Gotcha... Howard's Cams at competitionprodutcs.com has some nice hydralic flat tappets for $60 also, used them many a times as well.
Old 01-25-2009, 09:05 PM
$75 at http://www.sdparts.com/product/12371...LifterKit.aspx
Lifters v8hed Engine 9 06-10-2008 06:39 AM
Damage to Cam Lobes and Lifters on 454. What caused it? leejoy Engine 58 12-01-2007 12:18 PM
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 01:31 PM
Roller Lifters - standard cam ckucia Engine 27 01-27-2006 01:05 PM
lifters won't stop ticking - help Litdave Engine 6 07-24-2004 11:50 PM
