Striped intake hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2010, 05:53 PM
truckboy61's Avatar
Striped intake hole
I was bolting on my new intake and one of my bolt holes striped out ! What are my options? It's one of the center bolts next to carb
Old 06-18-2010, 06:27 PM
406 bug's Avatar
9.82 @ 139mph
Even though its stripped you could most likely use a stud and nut. I have put 35 lb on nut with a stripped 3/8 stud with no problem.
Old 06-18-2010, 06:33 PM
truckboy61's Avatar
It must be crossed threaded I can only get two turns at best then it gives way ?
Old 06-18-2010, 07:04 PM
406 bug's Avatar
9.82 @ 139mph
Try a tap to dress the thread. You may have to heli coil it.
Old 06-18-2010, 07:11 PM
Last journal entry: Some More Roll Cage Fabrication
If this is a SBC be careful using a tap. The chips could fall down into the valley of the engine. The two center bolt holes go straight into the lifter valley. I would pull the intake and dress the threads like 406 bug said just making sure to keep all debris and chips from entering engine. Good Luck. Another tip if you have an aluminum intake is go ahead and heli coil your carburetor mount threads with the intake off the engine. Save yourself the headache of having to do it later. Good Luck.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Right cam for a 383? atomicrockerdude Engine 22 11-02-2009 12:13 AM
Hole in Intake manafold Eddie Thompson Engine 1 09-02-2009 11:52 AM
chevy sb performer intake temp sender location tnsbyrd Engine 2 07-04-2009 11:01 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
