Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Striping in paint
Old 02-15-2013, 05:54 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
If you clear over it ,it will show...To fix it you should sand any roughness ,usually the light spots will be a bit rougher. ,so give it a quick ,light sanding and hold the gun a little closer so your spraying it a little wetter and (heres the trick) now spray in the oppisite direction...you were going side to side ,now you want to go front to back,back to front...say goodbye to stripes...
I'm not sure what kind of base your using but I had a lot of trouble with Omini doing this and had to go with slower reducers also...
