stripped bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2003, 12:48 PM
stripped bolt
i have a stripped bolt and was wondering how i could get it out?
it is on the diff.
Old 11-16-2003, 12:59 PM
Jmark's Avatar
Is it stripped or broken? Stripped bolts usually come right out.
If the hole is stripped, you will need to by a Helicoil kit and drill it out, tap it and insert the correct size Helicoil.
If the bolt is stripped and left its threads inside the hole, you can usually run a tap in it and clean it out.
Old 11-16-2003, 01:03 PM
no the head of the bolt is stripped. can someone help me
Old 11-16-2003, 01:09 PM
Jmark's Avatar
Ahhhh, now I see.
Couple of options.
first is to try to file it back to shape and then pound on a good 6 point impact socket and try again.
Another is to weld a nut on top of the rounded on and try again.
Last thing you can try is use a chisel and try to un-screw it by turning it with the chisel and hammer.
Old 11-16-2003, 06:56 PM
Dutchman's Avatar
Old Salt
If you can't weld a nut on it one other option is to drill a pilot hole and use an appropriate sized easy out. Make sure you oil (or thread breaker liquid, we called it wintergreen prior to the Navy outlawing it ) the bolt up good to ensure breakage of threads.
Dutch
Old 11-16-2003, 06:58 PM
poncho62's Avatar
Wiki Edits: 5
Isn't that why they invented vise grips.
Old 11-16-2003, 07:02 PM
Dutchman's Avatar
Old Salt
Dang Poncho, forgot about that required tool!
LOL
Dutch
Old 12-23-2003, 09:14 PM
New Member
ROUNDED BOLT HEAD
I HAVE HAD SOME LUCK REMOVING BOLTS WITH ROUNDED HEADS USING SMALL PIPE WRENCHES THATS OF COURSE IF THERE IS ENOUGH ROOM TO GET THE WRENCH ON THE HEAD.
Old 12-23-2003, 09:18 PM
poncho62's Avatar
Wiki Edits: 5
I just bought a reverse biting socket set. Its made for rounded bolt heads. I got it here in Canada at Canadian Tire. Havn't tried one yet, was wondering if anyone knows how well they work.
Old 12-23-2003, 09:21 PM
adtkart@aol.com
One advantage of the "weld a nut on" process is that the heat many times helps loosen the bolt.
Old 12-23-2003, 10:02 PM
Tazz
I agree with welding a nut on top of the stripped head. Good luck!
Tazz
Rat Rode Rule!
