stripped filler bung on rear differential - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 04:58 PM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
The filler bung on my differential (93gm pick-up) is one of those ones that you use a 3/8" socket extension on. Mine is stripped and I can't get it out. Is there any fix for this?
murray
Old 07-07-2005, 07:03 PM
Chisel,hammer,persistence.Good luck.
Old 07-07-2005, 07:18 PM
can you get a pair of vice grips on it? i've had success with them in the same situation.
Old 07-07-2005, 08:00 PM
New Member
stripped plug
Take a 3/8 bolt, not too long and stuff it in the area that is stripped.
Then wire feed weld the bolt to the plug. You shouldn't need to weld all the way around the bolt. If you do, take care to weld a small area at once , let it cool and the weld some more.
This will work. Been there, done that!!
Old 07-07-2005, 10:08 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I agree with nomad55, but I would sacrifice a 3/8 extension to weld to it, just after welding try to turn it out, use the heat from the weld in your favor.
If not the hammer and chisel will work also.
Steve
Old 07-07-2005, 10:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
weld a 3/8 drive extention onto it.
While it is hot melt some candle wax on it to flow into threads.
Let 'all' cool down ... fullly
twist the plug out
Old 07-08-2005, 05:06 AM
murrsue's Avatar
I have an old 3/8" extension that's a bit buggered and will gladly sacrifice it. I have no welder though but should be able to get some friends to help. Thanks guys!
murray
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
Rear end Buffed Engine 3 10-31-2002 05:11 AM
replacing rear differential - what should I do? Johnny Bravo Transmission - Rearend 5 10-26-2002 10:19 PM
rear differential swap nomad55 Transmission - Rearend 1 03-04-2002 05:24 PM
