stripped regulator shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2004, 07:58 AM
I know there are aftermarket replacement window and door handle shafts available for my '54 F100, but I'm wondering about less expensive options.
Anybody know if there are junkyard shafts that will fit my regulators?
Another option I was thinking about was tapering and welding some onto my shafts. Anybody ever tried this?
Old 02-05-2004, 08:16 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
I'm afraid I know little of 50's F100's but I have discovered something interesting. My "regulators" in my 67 Mustang were worn out. (Technically, the actual small shaft assembly is the "regulator" and the rest of the assembly is the "scissors". Commonly when people say regulator, they mean the entire assembly.) After some junkyard digging with my bad part in hand, I discovered the regulators in 79-93 Mustangs were absolutely identical. I only needed to drill out the three small rivets, swap them, and use new pop-rivets. Completely fixed my window problems with genuine Ford parts. Actually, I ended up using some from a Ranger as they had a slightly longer shaft which suited me better.
I hope you have similar luck. Certainly don't confine your search to just trucks, nor even to the 1950's. Sometimes Ford engineered a simple part that worked and obviously stuck with it, sometimes as long as 30 years.
Old 02-09-2004, 10:39 AM
Thanks Gypsy, your advice is encouraging. I'll be looking at various regulator shafts next time I go to the boneyard. I'll especially want to look at some Ranger regulators. The longer shafts will help me when it comes time to fab the door panels.
