you can get spark plug heli coils. just drill it slow and put a lot of grease on the drill bit, to catch the shavings, keep it clean too. then do the same with the heli coil tap, lots of grease and keep it clean.
re; stripped spark plug hole
there are also several co's make an insert that threads into the hole. The kit has 2 taps 1 coarse,1 finish, of course,do the grease trick and use air to blow out the hole, put it in with locktite (usually supplied with the kit) and replace the plug. They come in several lengths.good luck!
Are you sure there is no damage to the valve train?? sometimes when a belt goes the valves collide with the pistons. With respect to the plug- since you pulled it out I assume you can get it back in. That being the case, take some JB weld or other epoxy, coat the threads and tread in back in. Plugs will last for 80,000 plus miles so what the hay!!!!
Mark |
[QUOTE=Jmark]ROFLMAO!!! Yea Baby,,,I like how you think, must be a redneck like me! (is everyone in AZ like you and me? LOL)
Mark[/QUOTE you got it . I order bailing wire in the 100yard reels!!!!!!!!!! |
sam-missle |
K-D makes a kit for putting the insert in, IIRC it's about 15.00-20.00..You drill and tap the hole oversize then stake the insert in place..I've done a couple of them on our Acura...Like others said, use a blowgun with a tube attached down in the cylinder and keep blowing the chips out of the sparkplug hole.
later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Spark Plug Tech | ChevelleSS_LS6 | Engine | 17 | 06-28-2006 08:45 AM |
| Spark Plug wire looms and Ram Horn exhaust mainfolds | Jag Daddy | Engine | 6 | 07-19-2005 09:13 PM |
| Cylinder pressure vs. spark plug gap | 70bird | Engine | 3 | 05-28-2005 08:25 PM |
| spark plug gap | 74huggerorange | Engine | 6 | 12-29-2002 09:18 AM |
| bolt hole stripped holding carb down | impala dreaming | Engine | 12 | 12-20-2002 05:41 PM |
