stripped stud - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2005, 07:29 AM
stripped stud
I have a stripped wheel stud on the front hub of my 49 chevy pick up.
(drum brakes) I never had to remove one and replace it.
What is the procedure to remove and replace it.
Help would be appreciated
Old 02-20-2005, 08:35 AM
BOBCRMAN@aol.com's Avatar
Take a three lb. hammer and drive the bad one straight out the back side of the hub. Go to a "REAL" auto parts store and get a matching new stud. Insert from back side. Pull into place with a new, well lubed lug nut, with some washers to act as a bearing surface. Replace wheel.
pontiac 389 broken rocker stud tree_entz Engine 4 06-08-2004 01:29 PM
stripped Engine block... Echofive Engine 14 12-17-2003 09:10 AM
installing a new rocker stud 87 350monteSS Engine 7 08-26-2003 10:01 AM
Got the nut off. How do I remove the %$#^&% stud? asennad Engine 26 07-19-2003 02:32 AM
stud removal reluctant_paladin Engine 6 05-13-2003 06:51 PM
