stripped torq converter bolt how to remove - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2012, 03:58 PM
as the title sez, stupid brass nuts from the torq to the flywheel are sooooo
soft and stripped the beotch using a 6 point socket Grrrr.
so what kinda tool is recomended for loosening this troublesome culprit ?
was thinking an offset vice although never seen one.
Regards
Rick
Old 06-12-2012, 07:49 PM
LATECH's Avatar
Try one of these. Irwin makes them, so does snap on and many others.
ID:	66022   Click image for larger version
Fact is stranger than Fiction
Old 06-13-2012, 05:55 PM
but what do you use after it's stripped. was thinking there might be a biting wrench that grabs with tension. or an offset type vicegrip.
Old 06-13-2012, 05:56 PM
same
Doh never mind now that I zoomed in the pic I see it has some sort of biting edge. what are they called ?
BTW thanx.
Old 06-13-2012, 06:08 PM
LATECH's Avatar
They are bolt extractors, for stripped fasteners.
They bite harder as you crank on em, works well. I have 3 sets, different styles.All snap on.
stripped bolt hole 74mav Engine 2 08-14-2011 07:34 PM
How to remove broken screws from torq thrust wheels Ripped Suspension - Brakes - Steering 5 12-29-2005 07:29 PM
Torq converter lock up? jigga99 Transmission - Rearend 1 05-12-2005 10:35 PM
stripped bolt jo5hi3 Engine 10 12-23-2003 10:02 PM
torq converter 1969cutlass Transmission - Rearend 2 08-02-2002 02:52 PM
