Stripping the dash hardware
I am nearly to pull the last stubborn part of my 66 ford pickup cab, does anyone know how to get that 355,000 mile ignition switch out? I turned it to ACC, poked a tiny allen wrench in the lock pin hole, wiggled the key, (by the way, when I try to pull with the key and at the same time push pin hole, the key is so worn, that the key comes half out of the while pushing pin hole when I pull the cylinder, but it does not want to come out. It has a spring around the switch on the back of the dash, and the front dash is the bezel. Under the spring on the back side has a inner housing to mate up to the back of the dash and hold the enitre swtich.
I have people told me to use wax, or have a new key made, do locksmiths just know how much to grind to match of the key when it was new? Any body know how to get it out, should I just cut the bezel and buy door locks and a new switch with matching kit? The switch and door locks are usable, but worn. Footstomper |
65 mustang,
I tried all of that, it was in there for 350,000 miles and the key rarely works on ACC, I was hoping for pulling it out, and you would probably knew more than I did. I have pulled those locks before. This was the worst. I decided since the cluster was out of the 66 ford truck, I had plenty to use a cut off saw, once I took off the back contacts, I carefully saved the external spring. Next I got the spring and collar by grinding the housing and it came out. I saved the expensive items, 29.00 for the bezel, collar, 12., spring, 4, The 14. dollar switch and 8. key and lock. I probably could have been able to punch the lock from the back without all the grinding. The contact plates had already fell out. So, now I am ready to paint inside and outside, frame, etc. Thank you for responding, I was beginning to think that nobody would answer. I was in hurry to get through with the truck, I need it badly. My neighbor does not like my sandblasting and painting, it is in the county though. I don't do it very often. |
When turning it, while pushing in that hole, you have turn it left past the acc position to get it out.....
Ontario Rodders |
| Recent General Rodding Tech posts with photos |
| justdashes/trashes my dash | cozmo | Interior | 22 | 12-28-2012 08:15 AM |
| 70-72 Chevelle Chevelle dash wiring Problem | skeeveman | Electrical | 18 | 01-10-2011 07:44 PM |
| 1964 Impala SS Dash | 64Joker | Interior | 3 | 06-21-2007 11:30 AM |
| Fiberglass dash help. | americanLT1 | Interior | 1 | 09-08-2006 01:27 PM |
| Mounting fiberglass dash | mrmagoo187 | Interior | 24 | 11-04-2005 05:43 PM |
