Stripping paint and repairing sheet metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2011, 09:10 PM
The more I've been working on my car, the more hidden, bad repairs I'm finding. I want to strip the whole car so that I can find them all. Will the car be OK sitting in bare metal for a month or so while I repair the sheet metal? For the most part I only get to work on the weekends. I know the car will need at the very least quarter skins, trunk drop offs, and the lower tail panel. How do you guys, that only get to work on the weekends, tackle stuff like this? My car is in a garage.
Old 04-07-2011, 09:40 PM
some light surface rust may flash up depending on the humidity, nothing some naval jelly and steel wool wont clean up before you get ready for epoxy. rinse with hot water and dry quickly. I usually use 80 grit after the metal is rinsed, dried, wax/grease remover wiped down, - right before a good couple coats of epoxy.
if the humidity is horrible where you are, then look into a dehumidifier, but for the most part you don't need to worry about a little flash rust while your workin metal.
good luck!
Old 04-07-2011, 09:44 PM
Do one thing at a time once you take it all apart you have a big mess I made this mistake with my truck. I have a 76 k5 blazer and its down to the bare cab. no nose, no quarters, no doors, no tailgate. I cut the floors and the rockers were gone. now all I have to do is put it back together but its a long job.
I say do one side of the car at a time and you will get it done. As far as the bare metal issue you should be okay for a few months as long as you dont live in a humid area. if you do dont waste your time and money until your ready to prime the car.
Old 04-08-2011, 12:10 AM
I'm also a weekend warrior for the most part. When I had both of my fenders stripped, I used a zinc phosphate coating to protect them against flash rusting, but even this isn't fool proof. I have had bare metal sit all winter and never rust. My car is also in a garage. once the humidity comes in the summer days things start to become a different story and my fenders were constantly rerusting on me. It seemed if I degreased them and didn't touch them with my bare hands it helped, as sometimes I would actually find flash rust spots exactly in the shape of my fingers.
Ultimately, the best strategy I came up with was don't strip something to bare metal until I'm ready to work with it, and I have everything lined up so I can move through the process as quickly as possible. It took that and going over the panels a lot with 80 grit on a DA and/or possibly a wire wheel to physically remove rust. Right before I was ready to paint I did a zinc phosphate treatment to neutralize/remove any corrosion that I couldn't physically remove.
stripping to bare metal? builtbyagirl Body - Exterior 2 03-16-2010 06:47 PM
metal paint stripping kriscrash4x4 Hotrodding Basics 3 03-14-2010 07:07 PM
Stripping to bare metal ,patch panels, and prep 74chevyflat Body - Exterior 17 07-16-2008 08:23 PM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 08:48 AM
Repairing a "dimple" in Sheet Metal on Hood leejoy Body - Exterior 16 08-09-2006 11:06 AM
