stroke depth of master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2010, 03:47 PM
So to find this out I just push and bottom out the piston and thats my stroke. Trying to figure out my how far my brake pedal has to move. I only get 3/4 of a inch at this point (thats at 6 inch of pedal travel) so have to weld a longer peice on the piviot area
Thanks
ID:	43277   Click image for larger version
Old 01-18-2010, 09:24 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Double the length on the pivot part should give you half the pedal travel,
master cylinder plumbing maninacoupe Suspension - Brakes - Steering 4 11-07-2009 08:50 AM
Master Cylinder Help Needed glg97 Suspension - Brakes - Steering 2 11-06-2005 07:20 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Single to Dual Master Cylinder swazo Suspension - Brakes - Steering 2 10-19-2004 08:00 AM
