Sweet
Thanks KeithB123 for the info.
I was actually going to ask about cam next. I like your choice cuz I wanted something comp cams makes. Would a 1.6 roller rocker with pushrods +.100 work if I drilled the rod ports they didn't hit the sides of the heads, or would I have problems with piston to valve clearance. I have also heard of using 1.6 on the intake and 1.5 on the exhaust to offset the smaller exhaust valves. Any thoughts? If i used the 6.0 inch rods, would you suggest the 3.75 crank or the lower compression 3.48?
Thanks everyone.
I know that I can make more power per dollar with the bigger cubes, but i could still have fun with the smaller motor. I knew it could be done.
