well, the 305 heads dont flow the best , but you must remember the motor is only the size of a 302.It may not run with the big dogs,but you will certainly be the boss of the 302 dogs left on the step.lol mike
Re: Stroked 305
Cool
Yea, that's kind of what I figured, but I wasn't sure. One of my posts on this thread says what I plan do do, but I am not sure if it will work out. I will repeat what I put there in case anyone missed it. Any of your input would be great. 305 bored .040 over to 3.776 bore with KB186 pistons. 3.750 stroke with a 5.7 inch rod. Clearly I would have to get this assembly balanced. I know that there will be some machining involved so that the rods don't hit the cam and the balancing pads don't hit either. The compression height on these pistons is 1.433 and they have a 10cc D-cup head type. With a 58cc head, I believe I can get 10.1:1 compression, perfect for what I am running. I plan to use the World Castings S/R Torquer heads because they have 170cc intake runners the 58cc chamber I want and 1.94/1.5 valves. Plus, they are meaty, so I can have them ported and polished if i so desire. It was also suggested that I use a comp cams extreme 256 or 262 cam because of their midrange power. I would probably use the Performer Air-Gap I have, and probably a carb around 600cfm in size. i also already have a 6AL ignition with a Flying Magnet Crank Trigger and MSD distributor, so I would probably just put that set up on this engine. I was also looking at Supercomp headers. Any ideas?
334 cid
Even this thread is a few months old I wanted to mention that a 334 we did for our company using a set of 5.565 rods,.030 305 forged pistons and of course 400 flexplate and dampner. It was done with a set of old TRW 305 pistons a 1529 (400) crank turned down, .020 off the deck .024 of the intake surface of the 882 heads with believe it or not 1.72 valves little port window matching and throttle body. Even with the small intake valves it's quicker than most 350s around and definitely out pulls 'um. OH, ands MTC1 cam... Vaccum is unreal and 18mpg in a short bed 90 chevy. Biggest advantage we noted was it pulls a heavily loaded 2 axle dump trailer up through the mountains and never ran warm, and stayed in overdrive. The small valves were by chouce. took a while to find the heads. Thinking of building another one with cast pistons for my daily driver.
Need Glasses
Thanks American Muscle... Got any idea where I can get info on how to adjust the crank balance on a stock 2442 crank? I lightened rods by 6grams before I was finished with the balance fixture, Kinda like shaving side burns trying to get them even. Also my pistons and rings are lighter, altogether about 10 grams per assembly. My crank was well balanced before. Not scared to drill the crank, but can't figure out how much to take out, and can't find an appropriate thread for the formula. Thanks in advance. Duntov
re crank balance
Thanks Eric,
That makes me feel better but I would like to know more about crank balance. I think it would be a good thread to start because there is so little information shared about the details/specifics/science as it applies to v8s. I've noticed over time that if you have pressed pistons, the balance guy often either presses them on after or offers to. So when we get a small block in that's been balanced, (half of them) and press the pistons off, I clean and weigh them out. They usually average within a gram and a half from light to heavy. We do our own rods/pistons to a tenth gram. Not because we need to be to a tenth for our RPM range, but partly because I don't completely trust our fixture and scale that much. So figures if we are within a tenth or two that they hopefully are inside of a gram. The crank though, we're at the mercy of someone's computer lathe and never really know for sure, what we've got. You think enough people would be interested in the subject to create a new thread? Thanks Duntov |
There is no way you will be able to find anything that will tell you where to drill the crank at home just based off the amount you have changed the rotating and reciprocating weights as crank balancing is done on a dynamic balance machine, not static balance. With the small amount of your change just put it together, more than a few pro's "overbalance" the cranks they do, like 51-52% balance factor rather than 50/50, with the crank counterweights just a little heavier than the balance formula suggests.
re balance
I've no doubt you're right Eric. You too BBC, my lathe and bit comment was reference to a dynamic balancing fixture. Our balance buys used to call them balance lathes or crank lathes back in the day of analog fixtures 60s and early 70s. That's what I meant by lathe and drill bit. We had one in the shop in 69 and it dated back to late 30s Germany, but formulas have evolved since then not to mention accuracy with the newer digital units. I'm going to start a balance thread to see if someone with share the formula. Thanks Duntov
i've got an 305 bored 60 over and it ran pretty good before the computer went out of wack
