xxxxxxx xxxxxx cxxxxx xxxxx xxxx
Mopar 383 stroker
The 383 and 440 dimensions are not the same. The 383 is considered a low deck and 440 is a RB-raised block. To put the 440 crank into the 383 block you need to have the main journals on the 440 crank turned down to the 383 main journal size. With a .030 overbore you end up with a 434 or close to that. Some sources are www.440source.com. Another is www.musclemotorsracing.com. Another is www.hughesengines.com. These are all Mopar specific businesses and will lead you right. A more popular combination is using the 400 block and coming up with a 451. Very good torque motors although you can get up to 500 cubes out of the 383 with other stroker cranks that are available from the above listed places. Myron
xxxx xxxx xxxx xxxx xxxx xxxx
Yea, the B and RB which means "raised block" are of different dimensions, taller and wider is what it is. Not a lot but a difference, enough so that when Chrysler was putting 383's in the A body's and then went to the special order 440's, they outsourced it to make em fit, not a lot of 69 440 darts or Cudas out there but they were made. As lemondana said, the 400 block and 440 crank kicks *** and is a very popular mod. If you indeed have an all original 67 440, you more than likely have the 915 heads with it with the big valves, int 2.08 and exh 1.74 and closed chambers that will help on the compresion using flat tops. 67 crank is steel. 1500 to 6000 range in a 65 Cuda will be a complete torque monster with a mild rebuild using the 915 heads on the 383 you got now. Stay conservative on the cam, let the cubes and compresion with a good *** end, 8/34 with some 3:91's propel you to bliss!
| 383 stroker deiseling when I try to shut er down | tdhixon | Engine | 6 | 09-27-2007 12:31 AM |
| 383 stroker question | deeloccb15 | Engine | 3 | 09-18-2006 01:01 PM |
| where to get a quality 383 stroker kit ? (Long) | Mustangsaly | Engine | 1 | 07-18-2006 06:13 PM |
| 383 Stroker | Beowulf | Engine | 2 | 07-14-2006 07:08 AM |
| 383 mopar questions | nick | Engine | 3 | 01-22-2002 09:30 AM |
