Stroker 4 a 1994 5.7 block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 08:13 PM
I cant seem to find the drop in cranks to stroke a 94 350. I dont know the actual crank and rod diam. specs to just order one. that matches. I want to build a 383. They got the cranks for all the way up to 93.
Old 01-16-2011, 09:16 PM
Where are you looking. The catalog stores dont list everything thats available, just the stuff they sell the most off. Go directly to the crank manufacturers' websites(Scat, Eagle, Lunati,...). If you still cant find or figure out what you need, contact the companies directly, they all should offer some sort of tech line to call, or email tech service.
Old 01-16-2011, 10:08 PM
Scat
I've been e-mailing scat directly...I'm hoping the one i have found is correct. but i think it is for older blocks because the time line is up to 92. I'm still waiting on a reply email.
Old 01-16-2011, 10:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I see SCAT rotating assemblies at JEG's and Summit both, '92-'97 SBC, doing a simple search. Took me about 45 seconds. Like Fmrstr asked, where are you looking??
You only buying a crank? You'll need different pistons, for either 5.7 or 6 inch rods, you know all that I assume.
http://www.summitracing.com/parts/SE...ET&prefilter=1
Old 01-16-2011, 10:27 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Is this where you're looking: http://scatcrankshafts.com/
They list several grades of crank, 2-pc and 1-pc seal, 5.7 and 6 inch rods for the 3.75 stroke cranks for 350 blocks, no year designation.
3.75 stroke crank for either one piece or two piece rear main 350 block. What else do you need?
Old 01-16-2011, 11:25 PM
crank
i want the 3.75 stroke crank. i have not designated rod type and piston type yet. what are the pros and cons of going with a 6" or a 5.7"rod? Thank you.
1994 block to 350 trans shane.,herold Transmission - Rearend 2 01-16-2011 10:21 AM
1994 mustang building 408 stroker for car.need help Luke 200 Introduce Yourself 1 09-24-2010 03:21 PM
Stroker SBC with 880 block? 04SilveradoMykk Engine 5 11-25-2009 04:00 PM
big block stroker Tylor Sunaert Engine 1 09-25-2007 05:41 AM
What type of headders will fit a 1994 camaro with a big block? Shakey Jake Off-Topic 1 07-23-2006 08:34 PM
