stroker cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2013, 04:02 PM
stroker cam
hey e1 ,ive decided i want to go through my stroker ,the cam i would like to change but i dont really know that much about them.the cam that is in it is a cl-12-239-3 adv dur 262/270 ,im not sure what this means and a 462/480 lift which i think is the travel in the rocker arm, anyways im looking for a cam that will give me the rumble noise and perform better than this 1 without breaking the bank too.the heads are 72 cc ,2.02 int and 1.6 ex the block is bored .040 over, keith black flat tops 134, scat rods 31rc 5700, new crank cs383, 1.5 roller rockersscr1000,brngs r,m+c.. any kinda of advice on a cam that would work with these parts would be greatly appreciated .if you need more info let me know ,thanks alot ... i just want it to sound sweet and perform well
Old 02-27-2013, 04:04 PM
im also running a 600 holley with a edelbrock performer intake
Old 02-27-2013, 04:05 PM
this is also a pre 80s engine ,she been around
Old 02-27-2013, 05:32 PM
vinniekq2's Avatar
isky z-27 cam is awesome for a mild 350
are you taking your engine apart? do you know your CR? Are you looking for sound or power? do you know the deck height your are working with? will you consider a bigger carb?
Old 02-28-2013, 09:04 PM
not sure on deck height and a bigger carb isnt out of the question, would another carb make this thing perform better with the cam it has?
Old 02-28-2013, 09:05 PM
i love the rough idle sound ,and want to go when im ready to go
Old 02-28-2013, 09:33 PM
the gearing is 373's with 35 inch tires,also has a 2000 b&m holeshot converter
Cam for 408W stroker golferjc Engine 2 06-20-2012 09:10 AM
cam specs on a roller cam for a 416 stroker terry2012 Engine 1 01-21-2012 02:13 PM
best cam for 383 stroker Urbanfarmer Engine 13 09-04-2007 07:18 AM
383 stroker cam ? 280zxWith305 Engine 10 04-10-2005 02:46 AM
stroker cam rat_guerue Engine 8 10-19-2004 10:11 PM
