Stroker Clearance Methods and bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2007, 10:19 AM
Hey Guys,
I've searched the forum and have gotten insight on methods of grinding on the block for stroker clearance, but not sure about the details.
I understand that I need to install the main bearings, crank, 2 rods and pistons (minus rings) on the same journal. Then rotate the assy enough to see where contact with block is made and mark it.
Do I need to remove everything before grinding, or is there a way to cover up the rotating assy to keep the grinding debris from getting all over the new parts and scratching the pistons, bearings, and cylinder walls?
I believe I'll have to remove everything, but was hoping there might be a less
time consuming method that I'm overlooking.
On a different subject, I think I purchased the wrong bearings for my set-up.
I bought Sealed Power bearings from Summit. PN 4663 main, and 2555cp rod.
There is an ever so slight chamfer on the edges, as if perhaps from a deburring tool, but I don't believe it is enough to clear the radius on my Scat 9000 Chevy crank for 6" inch rods. Can I use these bearings just for the trial assy for grinding the block, or will they damage the crank or rods?
Does anyone know what bearing PNs I should use for a street stroker with
Scat components?
Any info would be a great help!
SS Monty
Old 04-21-2007, 12:39 PM
King of my Man-cave.
Plan on cleaning everything after you are done clearancing. Everything.
The crank you have is designed to be used with the stock-type bearings that you have. If you want to upgrade to a better bearing that gives you a little more clearance at the radius, you can use Clevite CB663H rod and MS909H main bearings.
tom
Old 04-21-2007, 01:36 PM
Thanks alot for the bearing information Machine Shop Tom!
I owe you one!
