-   -   stroker clearanced oil pan (http://www.hotrodders.com/forum/stroker-clearanced-oil-pan-146719.html)
GMR 10-16-2008 07:48 AM
When building a sbc 383 (350 block, Scat crank, 3.75 stroke) is a stroker clearanced oil pan usually needed?
petrat 10-16-2008 09:43 AM
oil pan
i have a eagle 3.750 crank and h-beam rods and it hit the oem pan...so you may need after market pan....i dont know what pan i have except that it is a racing pan....it came with the short block
richard stewart 3rd 10-16-2008 09:48 AM
Hi,
I did one for a 87 camaro & used the stock pan with no interference, it was a scat stroker Assembly.
Rich
GMR 10-17-2008 12:47 PM
thankyou both
curtis73 10-17-2008 01:34 PM
No worries in my stock LT1 pan with a 3.75" crank. Some guys even go with a 3.800" crank in a stock pan.
I'm sure it varies with the pan design, but they seem to be fine in most applications.
glen242 10-18-2008 01:40 PM
On my stroker I used a stock appearing 5 Qt oil pan from www.midwestmotorsportsinc.com.
Pan came 'in the white' so I painted it Chevy orange.
Pan fit ok, but the scraper was hitting a couple of crank throws. Bent down the scraper a little, with a ball pein hammer, until I got clearance.
One extra qt. of oil is what I wanted and got.
GMR 10-19-2008 08:42 AM
thanks Curtis and Glen.
