stroker clearanced oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2008, 08:48 AM
GMR GMR is offline
When building a sbc 383 (350 block, Scat crank, 3.75 stroke) is a stroker clearanced oil pan usually needed?
Old 10-16-2008, 10:43 AM
oil pan
i have a eagle 3.750 crank and h-beam rods and it hit the oem pan...so you may need after market pan....i dont know what pan i have except that it is a racing pan....it came with the short block
Old 10-16-2008, 10:48 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I did one for a 87 camaro & used the stock pan with no interference, it was a scat stroker Assembly.
Rich
Old 10-17-2008, 01:47 PM
GMR GMR is offline
thankyou both
Old 10-17-2008, 02:34 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
No worries in my stock LT1 pan with a 3.75" crank. Some guys even go with a 3.800" crank in a stock pan.
I'm sure it varies with the pan design, but they seem to be fine in most applications.
Old 10-18-2008, 02:40 PM
On my stroker I used a stock appearing 5 Qt oil pan from www.midwestmotorsportsinc.com.
Pan came 'in the white' so I painted it Chevy orange.
Pan fit ok, but the scraper was hitting a couple of crank throws. Bent down the scraper a little, with a ball pein hammer, until I got clearance.
One extra qt. of oil is what I wanted and got.
Old 10-19-2008, 09:42 AM
GMR GMR is offline
thanks Curtis and Glen.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
stoker oil pan question 350rebuilder Engine 4 02-22-2007 04:00 PM
SBC Stroker Oil Pan Problem?? 89SDime Engine 2 02-12-2007 04:07 PM
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 07:33 PM
Oil pan - kicked out sump good? dh79 Engine 4 06-15-2005 02:32 PM
