Stroker flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2012, 10:56 AM
Stroker flywheel
I have a 383 stroker that is internally balanced. Forged 400 crank and have starter issues. I put on a 168 tooth 350 flex plate and it does not seem to go on right {straight}. I also have another 168 tooth that seems to push the outside of the plate towards motor the way it is built. When the starter turns it will not disengage all the way. Is there a diffferent flex plate for the 400 crank that is not externaly balanced or do I have other issues. Any help appreciated.
Old 11-04-2012, 11:23 AM
hcompton's Avatar
Old & Furious
All 400 from the factory were externally balanced. I have herd of weights being removed from flex plates. But not sure if thats the right thing to do in your case. The machine shop should be able to recommend you the correct part number. Since they did the work they will know best what parts you need.
Old 11-04-2012, 12:33 PM
Last journal entry: was hoping for better than this
your starter nose the bolts in a line or stagered
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 12:12 PM
Flywheel and clutch advice for 383 stroker v8hed Transmission - Rearend 4 03-19-2010 06:09 PM
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 10:43 AM
1-piece sbc flywheel vs LT1 flywheel curtis73 Engine 2 12-02-2007 06:02 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
