Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stroker oil pan w/main studs for windage tray
Old 08-25-2010, 07:08 PM
popo1984 popo1984 is offline
The machine work was done at Houston Engine and Balancing. To tell you the truth I dont know. I do know that the machine shop I used has a very good reputation in Houston. If they went through the extra steps to bore and hone with deck plates then I would assume they would align hone with the studs installed since the block was returned from the machine shop with the studs in the block.
