Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stroker oil pan w/main studs for windage tray
Old 08-26-2010, 06:13 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by popo1984
Ok well im using the scat 6'' pro stock rods. i might look into this. could save 200 bucks. Is there anything to gain by going with a milodan pan.
Using those Rods, you may not have to clearance the Block pan rails at all.
Milodon pan may make a little more HP at Hi rpm, depends on Pan & Tray design.
