stroker oil pan w/main studs for windage tray - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 09:03 AM
I have main studs installed for a windage tray in my 383. can somebody refer to which pan I should use. its a post 87 roller block going in my 72 c10
Old 08-25-2010, 11:21 AM
edge's Avatar
Time is short, are you ready?
I have a Moroso #20190 pan on my 383 with studs and Milodon windage tray and it works fine. http://www.edgesz28.com/edgesz28/engine.htm
See page 36 of Moroso Catalog: http://www.moroso.com/catalog/pdf/Oi...ccessories.pdf
You will need the #20205 pan for an 86' and newer block
http://www.summitracing.com/parts/MOR-20205/
Best of luck, Ed
Old 08-25-2010, 12:03 PM
Ok thanks alot. I was confused with what I actually needed
Old 08-25-2010, 06:08 PM
406 bug's Avatar
9.82 @ 139mph
Just curious, did you align hone the mains with the new studs installed?
Old 08-25-2010, 07:08 PM
The machine work was done at Houston Engine and Balancing. To tell you the truth I dont know. I do know that the machine shop I used has a very good reputation in Houston. If they went through the extra steps to bore and hone with deck plates then I would assume they would align hone with the studs installed since the block was returned from the machine shop with the studs in the block.
Old 08-26-2010, 01:33 AM
SSedan64's Avatar
The 96-98 Vortec truck engines came with a windage tray so that may be a cheaper option, depending on Tray size/shape.
Example:
http://cgi.ebay.com/ebaymotors/GM-5-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/GM-35...Q5fAccessories
Old 08-26-2010, 07:08 AM
definatly a cheaper option. but will the oil pan clear a stroker crank
Old 08-26-2010, 12:13 PM
SSedan64's Avatar
Yes, the last one I used didn't need any massaging of pan.
The older Blocks & pans normally need more grinding & a few hammer taps on pan rail for Rod clearance. Type of Rod will determine how much.
Old 08-26-2010, 12:28 PM
Just a couple of thoughts . . . Most all of the aluminum cast oil pans will not work in a stroker application (they are a bit narrower internally), at least they claim they don't work on a 400 . . . . Also, when buying studs (like ARPs, etc) for the mains, I think a 383 requires buying the 400 studs. I think. Gotta get the windage tray down below the crank throw. How did I come to this conclusion, you ask? ? ? Bought learnin'
Old 08-26-2010, 01:02 PM
Ok well im using the scat 6'' pro stock rods. i might look into this. could save 200 bucks. Is there anything to gain by going with a milodan pan.
Old 08-26-2010, 05:13 PM
SSedan64's Avatar
Using those Rods, you may not have to clearance the Block pan rails at all.
Milodon pan may make a little more HP at Hi rpm, depends on Pan & Tray design.
Old 08-30-2010, 07:23 AM
Ok Thanks for the info
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
oil pan on concord Furytom Engine 8 09-11-2009 10:55 AM
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 06:33 PM
8BA flathead oil pan cleanout plate powerrodsmike Engine 0 09-13-2005 04:52 AM
Oil pan - kicked out sump good? dh79 Engine 4 06-15-2005 01:32 PM
