stroker running cold - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2012, 12:11 PM
Last journal entry: my 88
hi i have a Chevy 383 stroker that's newly built. and it wont get up to temp it will come up to mayby 160 if i idle but once i go down the road it drops to almost 120 it don't have the clutch fan i think i have a 190 thermostat what can i do to bring up the temp
Old 12-14-2012, 02:20 PM
hcompton's Avatar
Old & Furious
You sure the thermostat is in there? Sounds silly but that will cause your problem. Also if its stuck open will do the same thing. Either way sounds like you need to buy a new thermostat and get it installed.
Fan cant cool the engine unless it gets up to temp. The temp sendor is in the right location?
Old 12-14-2012, 02:26 PM
I had an issue w/ a temperature gauge once & it was doing the same thing. Feel the top & bottom radiatior hoses while its running & if they are hot to the touch then the gauge is your problem. If they are cool then you have a different issue.
Old 12-14-2012, 02:31 PM
XNTRCI-T's Avatar
AKA Lee in KC
Umm, hcomp, you wanna re-think that?
Old 12-17-2012, 09:24 PM
Check your engine temp with an automotive multimiter designed to check temperatures. Check your thermostat to see if its functioning correctly. You may have to go with a higher temp thermostat. My brother did an engine swap into a mazda pickup that came out of an areostar van. I dont remember what temp his thermostat is but he has electric fans set up on it and they dont come on unless he has been sitting still long enough but going down the road the cooling is sufficient and they stay off. His fans are set a few degrees higher than the thermostat. He hasnt had a bit of problem at all from his cooling system
Old 12-17-2012, 10:04 PM
hcompton's Avatar
Old & Furious
If the thermostat is not opening then the fan does not really play into it. It would get hot! Very hot then the thermostat would open and engine would exchange water with cool water from the radiator. This exchange should not happen all the time only when the water temp inside the block gets too high. If block water temp is low then fan is not the issue its the thermostat not holding the water to temp.
Old 12-17-2012, 10:43 PM
Check the coolant level cold. Try removing radiator cap while engine is cold and see if water is circulating immediately after start up. That means the thermostat is missing or stuck in the open position, which may not let the car warm up properly.
Old 12-18-2012, 01:19 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Some thermostats fail in the open position.
Semper Fi
Old 12-18-2012, 08:30 AM
vinniekq2's Avatar
does the engine get hot when you make a full throttle blast,then cool down?
Old 12-18-2012, 09:05 AM
im going to change the thrmo and the gauge i had a bad oil pressure Gauge after the first ride a mile down the road it went to 0 i almost had a heart attack. never will trust the electric gauges again
SBC running too cold need some advice eric32 Engine 16 01-16-2012 01:29 PM
305 ci running cold? roadman65 Engine 4 07-27-2011 03:24 PM
350 chevy running to cold? mrt86 Engine 12 03-22-2009 02:11 AM
Cold Running Problems CandyRed69 Engine 8 03-21-2008 03:59 PM
overheating or running to cold 70SPORT Engine 4 10-26-2004 07:38 PM
