Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Strong 4x4 Manual Transmissions
Old 01-29-2013, 07:02 AM
AutoGear AutoGear is offline
Hope you have plenty of room under there and a strong back LOL. The NV4500 is VERY finicky when it comes to lubricant. If you can find Castrol Syntorq LT 75w-85, its what you need. If you can't, then get the dealership equivalent. I've heard from Dan @ Quad in Roberts, Montana that guys have had good luck with the proper Amsoil equivalent. Personally, Id use the stuff from the $tealership and keep the receipt that way you have a leg to stand on if theres a service issue. A lot of rebuilders will blame the oil; to be fair, an improper lube will kill a 4500 in short order, its what Syntorq was designed for.
