Strong 4x4 Manual Transmissions
Hey guys I have a question. I have a 56 Chevy truck that I want to turn into my do it all truck. I have an LS7 to drop into it, as well as a line on an air suspension setup. I want a Hot Rod, and the LS7 should provide the muscle for that, but I also want to take my car to my favorite trailheads to go mountain biking, skiing, etc. So I need 4WD. But I also want a Manual because I enjoy driving. I know this is a complicated checklist, so ill simplify it:
4WD Manual Strong Does anyone have any ideas? thanks so much! |
I would also take the time to check out the Chevy NV4500 option, its a super strong transmission with a couple gear options. With that super low first you could crawl to any biking spot. just my .02c
Yeah, GM already did it for you, the NV4500, and you get a great low-1st which most 4x4 guys would want. Just step up with the $...
![]() Note if you go shopping, the GM and Dodge versions do not interchange. |
Hope you have plenty of room under there and a strong back LOL. The NV4500 is VERY finicky when it comes to lubricant. If you can find Castrol Syntorq LT 75w-85, its what you need. If you can't, then get the dealership equivalent. I've heard from Dan @ Quad in Roberts, Montana that guys have had good luck with the proper Amsoil equivalent. Personally, Id use the stuff from the $tealership and keep the receipt that way you have a leg to stand on if theres a service issue. A lot of rebuilders will blame the oil; to be fair, an improper lube will kill a 4500 in short order, its what Syntorq was designed for.
Could go with the old standby. SM-465. Strong transmission, very close to the SM-420 that could have come in a '56 Chevy pickup, but GM used them from '73? until the NV-4500 came out in '90ish. No overdrive is the only hangup there. The NV-4500 will get you simmilar ratio's + an OD
| 4x4 transmissions | stallion0606 | Transmission - Rearend | 11 | 08-12-2012 04:03 PM |
| Info on manual transmissions! | Nightrider | Transmission - Rearend | 2 | 09-15-2005 07:29 AM |
| Which Manual Transmissions | 29modela | Transmission - Rearend | 17 | 08-06-2005 05:48 AM |
| high toque manual transmissions | bigpimp2988 | Transmission - Rearend | 4 | 09-09-2003 05:59 PM |
| Manual Transmissions | BenH | Transmission - Rearend | 2 | 07-19-2003 01:00 PM |
