Stronger axle shafts for 8.2 BOP - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2012, 05:56 AM
Hello!
I have a 8.2 BOP rear end which I'm about to rebuild.
Is there any stronger axle shafts available to this axle??
I've only found two axles yukon YA G8.2BOP-L and Alloy USA 17131.
Is the yukon axle shafts any good? The alloy usa seems to be just some stuck shafts..
Is it worth buying?
I already bought eaton posi dif, 3.73 ratio and overhauling kit and done the blasting and paint job, so I'm kind of stuck with it because it's not so easy to sell in Sweden (quite expensive after shipping and taxes in Sweden) and I need to get the axle in my car as soon as possible because the short seasong has just started...
Old 05-08-2012, 08:40 AM
The Superior PA6062 is another option.
I think all three are OK for moderate horsepower and street tires. I have used all three of these and have no problems. They can be hard to find in stock so check around and order soon.
You can also get Moser axles for a little more money. The Moser is a nicer piece.
Old 05-08-2012, 09:27 AM
Thanks för sharing your experiences and showing me another axle shaft.
I've looked for a Moser shaft but I can't find any on their webpage or at any other place, do you know where to find it?
Old 05-08-2012, 09:43 AM
The Moser shafts would be a custom made part. Moser will make most any axle in 2-3 days. I would email or fax them a diagram of your axles with the important dimensions. Cost is about $300/pair plus bearings, studs.
Old 05-17-2012, 10:58 AM
I just completed a 8.2 rebuild
I went Summit who linked to their supplier (Moser I think--I'm not at home) They offered a racing axel that was magnafluxed for very little extra cost. I ordered and had them in around 3-4 days.
Had a ***** of a time with the pressed on wheel bearings. Very rare.
Old 05-20-2012, 10:33 AM
thanks all for answering!
I can't find any better axle on summit? Are you home now so that you can check?
Moser had been the best alternative if the shipping cost to sweden wasn't 50usd more expansive than the axles themself (and in sweden I need to pay 30% taxes on both parts and shipping).
Summit have good shipping prices and I'm about to order from them anyway so it would be nice to find some axles there.
Old 05-20-2012, 11:33 AM
Checked the paperwork
Home Now. I ordered Summit MSR-A28CST which is a custom application for Moser. This is the alloy axle for racing.
My housing number is 13885724F for a 68-70 Buick 8.2 --10 Bolt only. My gear is a 2.93 with a ring gear is 1382741.
As previously noted, be very careful. They also needed a custom axle order filled out. My bolt circle was 5 by 4 3/4. length 29.75, stud 7/16 by 20 press in. Here's the strange part --my axle end type was for a chevy even though it wqs believed to be the original axel in the 350 Skylark. Who knows, an early failure or GM using up the last of the 8.2 supplies? As I understand it, 1970 was the last year for the 8.2.
Henry at Summit handled it. 1-800-230-3030 Good Luck.
Old 06-01-2012, 03:36 AM
Wow, thanks a lot, really!
but is this with or w/o the spools? image shows with spools and info says without?
what engine are you running to the rear end? Do you know how much power the rearend can withstand with these axle shafts?
Old 06-01-2012, 11:39 AM
My dad had some custom axles made by Moser for his 55 chevy rear. Great folks to deal with. Price was so reasonable, he ordered either an extra pair or an extra single....I can't remember which. If I ever need custom axles, I'm headed there 1st
7.5 Axle id and ? about narrowing using ranger axle shafts johnhalabama Transmission - Rearend 4 07-23-2009 06:12 PM
A stronger TH350C awoodman Transmission - Rearend 3 03-02-2008 09:06 AM
a-body mopar axle shafts Arillious General Rodding Tech 8 07-23-2007 01:16 PM
Axle shafts a bit to short Brett_PM Transmission - Rearend 2 06-14-2007 09:10 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 06:23 PM
