Strongest 6-speed either stock or aftermarket . . . - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2005, 02:25 PM
Siggy_Freud's Avatar
I was curious as to the best option(s) for a 6 speed manual transmission. Eventually I'd like convert my truck from an automatic to a manual. I currently am running a th-350 with 4.10 gears. Id love to keep the gears as well as have two gears of overdrive. Any thoughts on good transmission options?
Bringing history and technology together.
Old 08-08-2005, 03:36 PM
What type of engine are you currently running?
What is the power output range you are hoping to obtain?
Old 08-08-2005, 04:33 PM
PapaG's Avatar
Ask me, Cause I don't know
Last journal entry: Kid Dean Car
http://www.ttcautomotive.com/English/products/T-56.asp
Check here, more than strong enough.
Richard
Old 08-08-2005, 05:06 PM
dh79's Avatar
There are a lot of companies that will sell T56's capable of 400-450 ft/lbs torque.
If you need more, G force makes an upgrade kit for the T56 that'll take even more power.
G force T56
And if you need even more than that, you can get a jerico, G force, or liberty's gears racing transmission; as long has you have a lot of money to spend.
dh
Old 08-08-2005, 05:36 PM
Currently the engine is a TPI 350 producing somewhere in the mid 300's for hp and probably a tad over 400ft lbs or torque. Eventually I will be building a turbocharger system for it and would like to have a transmission that will handle such power. While that probably wont be for a year or two at least, its always good to plan ahead. I plan on making 600-700hp with the turbo application.
Old 08-08-2005, 05:42 PM
Would it be more economical to have a T-56 rebuilt to handle higher power from the get go? Also, how is the gear ratio spacing compared to a th-350? I'd imagine it is tighter as there are more gears. I imagine this would be more beneficial for keeping the engine in its desired RPM power range.
Old 08-08-2005, 07:31 PM
The G-Force ratios are here:
http://www.g-forcetransmissions.com/T56Ratios1.pdf#search='T56%20ratio'
Tremec ratios are here:
If you read the bottom of the G-Force info, you'll see the majority of the stock T-56s are a 2.66 first, which is pretty close to the TH350s 2.52 first.
Old 08-09-2005, 07:45 PM
strongest 6 speed
I believe Corvettes used a ZF 6 speed in the mid 90's? This transmission is supposed to be super stout.
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 11:21 AM
new world truck speed record hoodoo Hotrodders' Lounge 4 01-10-2007 12:43 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Th350 to 4 speed auto conversion Bandit1980 Transmission - Rearend 3 12-29-2004 07:41 PM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 11:20 AM
