-   -   Strongest motor mounts? (http://www.hotrodders.com/forum/strongest-motor-mounts-109971.html)
jacobm99 02-25-2007 11:31 PM
I'm thinking of putting a cummins into a older blazer and would need to fab up motor mounts. I was wondering if any one had any insigt as to which type of motor mounts were the strongest. I'm thinking of either going with the Spool type or the pad type. Either way, I would put 2 on each side.
There's potentially going to be upwards of 700 ft/lbs of torque, possibly more. Any suggestions?
kuhn-77 02-25-2007 11:53 PM
can you stick the front clip (front frame section) off of a 3/4-ton or 1-ton dodge on it? and then just use the mounts and everything already on it made for the 5.9 cummins??????????
jacobm99 02-26-2007 10:59 AM
No, but I could probably weld the crossmember in. I was hoping though that I could creat something that was stronger than the stock set up....
seriousracer 02-26-2007 11:07 AM
why not plate the motor in solid?
there used to be a company that installed the b series into chevies in the 80. i think there are parts around for that...
Idasho 02-26-2007 11:09 AM
So you are looking to build your own mounts? Or modify existing mounts to work?
I build Urethane mounts for SHO taurus'. The SHO taurus eats factory motor mounts alive. I utilize the factory hardware, strip it clean of the factory rubber, and pour new mounts using the urethane.
It is a product called Flexane, made by Devcon.
Ive built upwards of 50 or so sets now, with some being in cars with north of 400whp.
So far, no failure. :) This urethane is TOUGH stuff.
bigbadbowtie 02-26-2007 11:29 AM
Ditto.......
jacobm99 02-26-2007 07:43 PM
I'm not sure if I know what that means, but I'm guessing that you're suggesting that I bolt the motor directly to the crossmember. If so, the only reason I don't think I would go that route is becuase the 24v are very loud and cause a lot of vibration, which wouldn't make for a very fun rig to ride in.
