Strut assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 11:03 PM
Strut assembly
I have a 1996 Nissan Maxima SE 5speed V6. I was just wondering if I could use a used Arm that will replace my bearing strut and spring assembly and would it be a hard task to accomplish on my own being that I am a rookie mechanic?
Old 06-20-2008, 01:22 PM
Holder350's Avatar
Auto Parts Professional
I dont know exactly what you are talking about when you say arm.....
but if you are trying to do away with the struts and go to a spring and shock type suspention then....even tho anything is possible with enought time and money, you'd be going to a outdated setup, not to mention the costs of
installing upper and lower a arms
trying to install ball joint knurls in the spindle
and not to mention the fact that with a front wheel drive you would have to use a torsion bar setup....
Sorry.....I'm rambling....
Grand Am Strut Replacement - Help leejoy Suspension - Brakes - Steering 12 08-30-2007 11:59 AM
Clutch pedal assembly for flathead Lee Hulick Transmission - Rearend 6 04-02-2005 09:11 PM
Strut Compressors ckucia Suspension - Brakes - Steering 5 03-26-2005 03:04 PM
Engine Assembly Lube ? bowtieorbust Engine 11 11-09-2004 11:24 AM
Hey Willy..Strut Question?? Dave E Shank Suspension - Brakes - Steering 12 02-13-2004 10:10 AM
