strut rod angle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2005, 12:52 PM
strut rod angle?
I am building a 37 plymouth pickup with a bobcat front end. Due to the angle of the strut rods they extend past the inside of the frame rails about 3-4 inches. Was wondering if anyone manufactures strut rods with a different angle, or could I shorten them with no ill effects. I don't see bending as an option. Any suggestions?
Old 02-27-2005, 01:12 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Don't know of anyone manufacturing strut rods of a different angle. Couldn't you build brackets to fit the end of the strut rods?
Old 02-27-2005, 04:49 PM
Wiki Edits: 49
I believe the Pinto and Bobcat front ends did have strutrods that had a different angle than the Mustang version.
It has been comon practice for most guys to just heat them with a torch and bend them to the desired angle and I haven't heard of anyone having problems with strut rods after adjusting the angles this way.
Centerline
Old 02-27-2005, 04:59 PM
To be "right", a piece of allthread rod through the lower control arm bushing holes in the crossmember should pas through the center of the hole in the strut rod bushing bracket, even though it will be at an angle. Other locations will work, but they won't be right.
Old 02-27-2005, 06:46 PM
They extend past the frame far enough to interfere with the exhaust, thats the problem.
Old 02-27-2005, 06:48 PM
Centerline
Could I use rods from a mustang? Do they interchange? As drastic as the bend would have to be, I'm afraid of compromising the integrity of the steel.
Old 02-27-2005, 06:57 PM
Depending on the length of the allthread, the bracket could theoretically be placed anywhere along the frame rails, just by changing the angle of the strut rod. I don't quite understand your point?
Old 02-27-2005, 08:55 PM
That;s right. as long as the rod passes throught the center of the mounting hole for the strut bushing, the length and angle don't matter.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
How NOT to do MII strut rod supports willys36@aol.com Suspension - Brakes - Steering 26 12-21-2005 08:00 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
