Strut suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2008, 11:12 PM
Strut suspension
I was wondering if any one had ever used a strut type suspension on the rear of a rod. i have been thinking, the strut with spring is for the most part like a coilover shock. Any thoughts? I have a 66 bug i am building from swap meet/wrecking yard parts. Gonna run a BBC, a tube or i-beam up front, and most likely ladder bars on the rear, the car is going to weigh around 2000 lbs, so what do yall think about a rear strut in place of expensive *** coilovers?
Old 03-19-2008, 09:24 AM
ckucia's Avatar
Some "Big" GM FWD cars used strut rear suspensions.
Allante, Riviera, and most of the FWD cadillacs from the mid-80s to the late 90s, IIRC.
Of course, they weren't powering the wheels through them...
Also the Fiero, IIRC, had a strut rear that was powered since it was mid-engine. Might want to see how GM engineered that for your bug. If the wheelbase is similar, you may be able to use parts off a Fiero to implement what you have in mind.
Just throwing out some suggestions...
Old 03-19-2008, 09:37 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
I would suggest a different direction. Take a look at the bottom of this page:
http://www.speedtalk.com/forum/viewt...rsche&start=15
You could consider the Porsche to be a "rich cousin" of your Beetle, so this Toronado swap is certainly not out of the question.
http://home.earthlink.net/~whshope
Old 03-19-2008, 11:30 PM
will most likely end up with a good set of used coilovers, just was seeing what other thought of struts on the rear. Thanks, RacerJ
Grand Am Strut Replacement - Help leejoy Suspension - Brakes - Steering 12 08-30-2007 12:59 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 07:29 PM
Strut Compressors ckucia Suspension - Brakes - Steering 5 03-26-2005 04:04 PM
Fatman Strut Suspension for Mustang msureb Suspension - Brakes - Steering 1 11-13-2003 07:52 AM
strut suspension for tube chassis Kenwalk Suspension - Brakes - Steering 1 05-15-2003 08:59 AM
