Stuborn Starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2006, 10:46 PM
Stuborn Starter
i am a dirt track racer i have a 79 camaro. i run it in the street stock class. it has a built gm 350. my starter keeps grinding the flexplate. i have tried a new starter and flexplate but still get the same results. it will turn over a few times then just start grinding the flexplate. i was wandering if anyone could help me with my problem
Old 08-31-2006, 11:42 PM
All you need to do is get under the car and with a long screwdriver lever the bendix gear on the starter out to engage the flexplate gear. Look at the mesh of the gears and it should be obvous how the starter needs to be shimmed to get proper alignment. Baiscally you want about .030 clearange on the gear teeth. It's pretty obvious when you get under there and check it.
You can buy shims at almost any large parts store.
Old 09-01-2006, 08:17 AM
thanks alot for the advice i will try that
Old 09-01-2006, 08:27 AM
NO problem, good luck. It should be a simple fix.
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 07:47 AM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 03:41 PM
Starter keeps starting and battery exploded Huug Electrical 13 10-06-2005 06:48 PM
Starter questions zipfactor Engine 6 08-07-2005 08:10 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 06:48 PM
