stuck brake drum - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2009, 09:39 AM
stuck brake drum
I've heated, beat, and even asked nicely and I still can not get my front drum off. any idea's. sure could use some fresh one's
Old 04-20-2009, 10:01 AM
I'm no expert but, try heating it around the center and using a couple big screwdrivers as pry bars or better if you can borrow a puller from a car parts store or garage
Old 04-20-2009, 01:45 PM
Pony's Avatar
Sounds like the brake shoes are stuck to the drum. See if you can back off the star adjuster, you may need to use wd40 or something like it on the threads. If you can back the adjuster off and the shoes back off too, you should be able to get the drum off. If the shoes are still stuck you can usually wiggle, jiggle and tap the drum to get them to break loose. Last resort take the axle nut loose, remove the outer bearing and get Mideveil and yank on it. Good Luck..
Old 04-20-2009, 02:24 PM
Cape Cod Bob's Avatar
More heat and beat
Old 04-20-2009, 02:53 PM
poncho62's Avatar
Wiki Edits: 5
If you get real desperate, you can cut the pins holding the retaining springs and undo the wheel cylinder from the backing plate....Then the whole works should come off together. Sounds like you are going to need all new parts anyways.
Old 04-20-2009, 02:55 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I believe that the drum comes off by removing the bearing cover , remove the large nut on the end of the spindle and pull the whole mess out bearings and all.. It does not come off like the rear drums.
I was not able to tell if you already had the other side off.. so I do not know if this is a how to question or a I already know how just having trouble getting this one side off ...
Old 04-20-2009, 02:59 PM
poncho62's Avatar
Wiki Edits: 5
Good point Pepi....I just figured he had already taken the bearing assembly apart........
Old 04-20-2009, 05:09 PM
T-bucket23's Avatar
Wiki Edits: 26
If you have alreay heated them and beat them, they are most likely junk now. If you cant back the adjusters off take Poncho's advise. Cut the pins from the back.
Do they move at all?
Chet
Old 04-20-2009, 05:51 PM
Will I ever get it done?
Last journal entry: Hood
Assuming there are no rivet heads in-between the studs (a dead give-away that you will need to do something more than "heat and beat"), take a close look at the studs just where they exit the holes in the drum. Chances are, you will see 3 or 4 swages. I remember using a swage cutter to remove drums from the front hubs when replacing them, all those years ago.
Poncho probably most accurately assessed the condition of your parts.
Long/short drum brake shoes wp442 Suspension - Brakes - Steering 2 11-10-2007 11:29 AM
Squeaking brake drum help needed! Hitorq Suspension - Brakes - Steering 7 01-02-2006 12:28 PM
'93 Stang GT Drum Brake Clicking sporks93gt Suspension - Brakes - Steering 2 12-03-2002 09:16 PM
Brake drum clank'n 5.0Towncar Suspension - Brakes - Steering 7 11-02-2002 07:48 AM
front brake diagram drum brakes 72chevyelcamino Suspension - Brakes - Steering 0 10-28-2002 03:17 PM
