-   -   stuck detent (kickdown cable) (http://www.hotrodders.com/forum/stuck-detent-kickdown-cable-48058.html)
dawg 09-19-2004 07:15 AM
ok after my 69 camaro came out of storage the detent cable was frozen solid?
its connected to a TH350 tranny.
removing the pan and cable I noticed the cable was not frozen but the mechanism the cable is hooked to is in the valve body.
So my question is can I free that up or do i need to remove the valve body and do a rebuild?
stu 09-19-2004 07:35 AM
Drop the pan and have a look at the lever.
There is a small clip that can be removed. This will give you a better chance at freeing it up.
dawg 09-20-2004 09:58 AM
ok ill try
