stuck detent (kickdown cable) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2004, 07:15 AM
dawg's Avatar
NAVY VETERAN
ok after my 69 camaro came out of storage the detent cable was frozen solid?
its connected to a TH350 tranny.
removing the pan and cable I noticed the cable was not frozen but the mechanism the cable is hooked to is in the valve body.
So my question is can I free that up or do i need to remove the valve body and do a rebuild?
Old 09-19-2004, 07:35 AM
stu stu is offline
Drop the pan and have a look at the lever.
There is a small clip that can be removed. This will give you a better chance at freeing it up.
Old 09-20-2004, 09:58 AM
dawg's Avatar
NAVY VETERAN
ok ill try
