Stuck in Drive? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2011, 01:55 PM
FatCouger's Avatar
Stuck in Drive?
we have a plane Jane 67 cougar, with351W with a automatic tranny (original i believe) . to our surprise when we went to move it wouldn't move, so we pushed it onto a tow dolly, put it in Neutral, and towed it at 25 MPH down a back road 4 miles to our new house. when we got there and unloaded it and we added ATF and it started moving, great! it was acting like a wheel was locking up feeling (weird) then pulled it up the driveway and tossed it into Park.
well, heres the oddity, it moves through the gears fine, but its in Drive. put it in reverse, its still in drive. what the heck would cause this :crazy: i cannot check fluid because its trying to go in drive, wont engage park :think: we checked all linkage etc all is fine.
Old 11-11-2011, 02:04 PM
tnsmith10's Avatar
when will it rain???
from what your explaining, the forward clutches are welded together. time for it to get a rebuild.
Old 11-11-2011, 02:08 PM
FatCouger's Avatar
it drove perfectly fine after a long sit, then this happened just trying to fire it up and move 4 miles, what would cause this? would too much fluid level cause it?
Old 11-11-2011, 02:09 PM
tnsmith10's Avatar
no, usually trying to move it without enough fluid or towing it without unhooking the driveshaft.
Old 11-11-2011, 02:52 PM
For those of you who dont know;
Unhooking the driveshaft (probably) would have prevented this. Do NOT put your car on a dolly and tow with the driveshaft in. Some people have done this and gotten away with it. Me? if its just not worth the 20min to pull the D/S, dont buy the car
Old 11-12-2011, 07:04 AM
Crosley's Avatar
Wiki Edits: 1659
Need to determine which automatic it is ... a C4 or a cast iron case automatic.
Cast iron trans may have rear pump that is turned by drive shaft, although I doubt it. These trans also suffered with linkage troubles internally. Manual valve could come loose and the trans usually slipped into reverse, but this one may be in "drive"
Old 11-13-2011, 12:50 PM
FatCouger's Avatar
i am pretty sure its C4, if thats what it is (il double check) what do i do to determine whats wrong? career mechanic but never been an automatic tranny guy really, but pretty sure i can work through it.
Ford Tranny Stuck in Drive Bubblehead Transmission - Rearend 6 11-21-2010 07:22 AM
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 04:29 PM
Front drive 3.8 Buick to rear drive trans Chopt 48 Engine 0 04-30-2006 02:43 PM
Drive shaft stuck in tranny? Deadtemple Transmission - Rearend 1 10-18-2003 07:26 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 08:47 PM
